Old 01-17-2013, 10:31 PM
majorlabel majorlabel is offline
Default Pro Tools 10 HD -- DAE 6031 HELP !!
I have tried EVERYTHING !! I Need expert guidance Please !!!!
get 6031 error messages constantly...every session, every time..
plug ins, no plug ins...doesn't matter...
thought maybe computer issue....bought new system intel i7, 3.5 ghz, 12 g ram, 1 TB HD + 500 MB HD for audio, no difference...
usage meter says everything great..no problems..still can't record or playback without constant 6031 errors...
done all the optimizations...
fresh new windows 7 64 bit....PT version 10.3 HD....
Core and Accel on PCI cards, could that be the issue ???
I have blue plate 192 and 96 i/o so whatever solution has to work with that
any REAL experts out there with REAL help for me ????? please
Old 01-18-2013, 06:26 AM
Default Re: Pro Tools 10 HD -- DAE 6031 HELP !!
Need to post a Sandra report so we can see the machine specs. If needed the details are in the windows LE forum as a stickie.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-20-2013, 10:19 PM
SiSoftware Sandra
ID
Host Name : nuprotools-PC
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS P8Z77-V LX
Serial Number : 1208014********
BIOS : AMI (OEM) 1502 11/09/2012
Total Memory : 12GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (4C 8T 3.91GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : ASUS Core (Ivy Bridge) DRAM Controller 100MHz, 2x 6GB DIMM DDR3 1.33GHz 128-bit
Memory Module(s)
Memory Module : Kingston KHX1600C9D34GX 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : ACI VK246
(1920x1080, 24.0")
Video Adapter : NVIDIA GeForce GT 610 (48 SM5.0 1.62GHz, 1GB 1.33GHz 64-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 610 (48SP 1C 1.62GHz, 1GB 1.33GHz 64-bit)
Compute Shader Processor : NVIDIA GeForce GT 610 (48SP 1.62GHz, 1GB 1.33GHz 64-bit)
CUDA GP Processor : NVIDIA GeForce GT 610 (48SP 1C 1.62GHz, 1GB 1.33GHz 64-bit)
Storage Devices
Seagate ST1000DM003-1CH162 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:)
Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) : 466GB (E:)
A-DATA USB Flash Drive (16.2GB, USB2, SSD) : 15GB (G:)
TSSTcorp CDDVDW SH-222BB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Removable Drive (G:) : 15GB (FAT32) @ A-DATA USB Flash Drive (16.2GB, USB2, SSD)
sessions (E:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm)
Hard Disk (C:) : 931GB (NTFS) @ Seagate ST1000DM003-1CH162 (1TB, SATA600, 3.5", 7200rpm)
Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-222BB (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS Panther Point LPC Controller
LPC Legacy Controller 1 : T0 C5-62
Audio Device : ASUS Panther Point High Definition Audio Controller
Audio Device : Gigabyte HDMI Audio stub
Serial Port(s) : 1
Disk Controller : ASUS Panther Point 6 port SATA AHCI Controller
USB Controller 1 : ASUS Panther Point USB xHCI Host Controller
USB Controller 2 : ASUS Panther Point USB Enhanced Host Controller #2
USB Controller 3 : ASUS Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP LaserJet Professional CP1520 Series PCL 6 (600x600, Colour)
Peripherals
Media Player : A-DATA USB Flash Drive (15GB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.1
Old 01-21-2013, 10:35 AM
Sandra Report attached, all drivers and bios updated...still having same issue....could this be a bus issue from PCI hd cards ?
System is connected through analog mixing board (48 channels), 192 i/o, adat 8 channel & 96 i/o + adat 8 channel (32 total i/o used)
please help me ?!
Sent from my SPH-D700 using Tapatalk 2
Old 01-21-2013, 01:43 PM
sunburst79 sunburst79 is offline
I have nothing specific to add at this time other than to say I would make sure you've done all the recommended Windows system optimazations to ensure that you starting out on a level playing field. And to run the DPC Latancy tester and see what it says.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-21-2013, 06:08 PM
DPC Latency checker
ran it..had some yellow due to lan controller so I disabled it..all green..but either way not a latency problem.
did optimizations...any other ideas ??
Old 01-22-2013, 01:29 AM
Raoul23 Raoul23 is offline
disable your usb ports other than 2 of them in the bios. Had this error when i first set my rig up, as soon as i did this everything was fine.
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-22-2013, 09:35 AM
Roland Clarke Roland Clarke is offline
Try another video card, I've just had the same issues with an Nvidia 210 and as soon as I disabled it the problems went away. I've had this same issue with a Pyramix system running an Nvidia card (that also has native cards). To test I ran using on-board graphics and the issue went straight away. I'm looking into something like a basic ATI video card.
Old 01-22-2013, 09:57 AM
I will try but the Nvidia card was recommended in the forums
-6031 Mateus Borges Windows 4 10-14-2012 03:08 PM
Error -6031 fisaac Pro Tools TDM Systems (Win) 19 04-01-2010 11:54 AM
8.0.1 cs1 still 6031 errors kinghand Pro Tools TDM Systems (Win) 30 11-18-2009 11:29 AM
Pro Tools DAE -6031 issues Haxie Pro Tools TDM Systems (Mac) 2 08-29-2003 10:21 AM
Enough of this 6031 Bug ZEUSS Pro Tools TDM Systems (Mac) 19 05-23-2003 12:11 AM
