Old 11-06-2011, 06:19 AM
Levitemusic Levitemusic is offline
Default Pro Tools won't recognize Transfuser
I just purchased the Pro Tools Instrument Expansion Pack and so far every other instrument (Velvet, Hibrid, etc.) except Transfuser works. When Pro Tools (10) is going through the plugins it stops and says...
"Pro Tools could not load the following plug-ins either because no valid authorization could be found, the iLok key waas not connected or the plug-in was damaged: Transfuser.dpm"
I checked my iLok on iLok.com and the Transfuser authorization is there (I did Not see a transfuser content authorization like I do for structure but maybe one is not needed).
I have tried trashing the transfuser plugin and re-installing it but I get the same problem.
Any help would really be appreciated.
Old 11-06-2011, 06:46 AM
DeadAgain DeadAgain is offline
Default Re: Pro Tools won't recognize Transfuser
Just reinstall PT10 .. over the existing PT10 installation ... simply rerun the installer. The installer includes a newer version that is automatically applied to Transfuser ..
Old 11-06-2011, 12:31 PM
Smile Re: Pro Tools won't recognize Transfuser
Thank You!!! It worked.
Pro Tools HD 9 Doesn't Recognize 2nd 192 io oechols Pro Tools 9 2 05-09-2011 06:18 AM
Pro Tools can't recognize 192 I/O Juraj Bernáth Pro Tools TDM Systems (Mac) 5 11-03-2010 08:46 AM
6/8 syncing transfuser to pro tools riggi Virtual Instruments 1 08-16-2010 09:08 AM
Pro Tools LE does not recognize more than 1 CPU done_411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-22-2010 06:32 AM
installing Transfuser full on Transfuser trial wfasano Virtual Instruments 2 06-30-2009 03:14 AM
