Old 10-28-2011, 06:21 AM
RapturesPittBull RapturesPittBull is offline
Default Newbie Help with Boom and Reason
I am using Pro Tools 10 and trying to connect my electronic drum set up to use as a triggering device for both Reason and Boom. On both of these products it finds the wrong pads for the channels and reason only finds 6 of my 10 pads. Any help?
Old 10-28-2011, 11:10 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Newbie Help with Boom and Reason
change the note assignments on the controller of your electric drums to match the boom / reason keymaps.....
Should be able to do that, however I have never tried to use boom as a VI.
Right click on several of the hit types in boom and see if it let's you "map midi"
If it does then hit the corresponding pad that you want the sound attached to........
trial and error....and try again.
Daniel
Can't open Reason 5 within PT :( Please help, Newbie < SamAndrew27 Pro Tools 9 17 09-02-2011 03:42 PM
Newbie ?: getting Reason to go through my PT speakers notr2d2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2009 04:56 PM
help! Reason Adapted newbie going insane scour79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-27-2007 04:18 PM
Newbie needs help with ProTools LE/Reason SIENNA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-06-2006 09:58 PM
newbie Reason questions GrahamCA General Discussion 3 06-10-2002 10:34 AM
