  #21
Old 12-31-2010, 05:20 PM
oulablank oulablank is offline
Default Re: Strike Overhead Panning Issues....Bug ?
I think we're misunderstanding each other . If you are printing kick mono , then you have to pan kick hard left or right . If you do that , then your kick will be hard left or hard right in the room channel..no ?
  #22
Old 12-31-2010, 05:56 PM
That is correct for Kick Center, Kick On Axis and Kick Front but I use the Master bus for Kick Room that is sent to the Room Channel for Width over Stereo. You will not print all Strike Channels in one pass.
Aaron Mulqueen - 001 HD Native
  #23
Old 08-12-2011, 05:47 AM
kev1 kev1 is offline
Hi oulablank, i realize that this is a fairly old thread , but i'm right there with you, I use strike all the time and am completely baffled with the hi hat placement , as soon as you go near building patterns the the h.h. position seems to jump all over the place in the OH ....have you had any luck resolving this?
kev
  #24
Old 08-14-2011, 07:24 AM
ok...so i've now gone though all the instruments , all the output config. i can find, the overheads are a fixed position, centre, i.e. mono, when the width is is increased or decreased there is a very slight expansion of the image , but it stays centre, the instrument pan faders have no effect on the instrument placement in the overheads, where as the instrument position changes in the rooms mics...this is the case for all instruments except the cymbals which have designated Left Right position in overheads,
to my ears the overheads are the best sounding aspect of strike ... but mixing with what is essentially mono overheads is very cumbersome ...my solution at this point is to use a combination of room and overhead channels and tweak them to give a more or somewhat exceptable image,
.....is there something i've missed
kev
  #25
Old 11-04-2011, 05:03 AM
100WChris 100WChris is offline
Hi Forum!
This is my first post and i was looking for a solution to the problem described in this thread:
I want to print separate tracks, but strike is getting confused with the routiung: i pan kik and sn hard left right to record them on Mono-Tracks via OUT1 . Now, in the OVERHEADS (stereo-OUT5) kik and SN is centered, but in the ROOM-Track (stereo-OUT6), kik is panned left and SN is pannedright
So: is this a bug or am i missing something?
Thanks
Chris
MIDI panning issues mojovoodoo MIDI 2 09-03-2013 06:41 PM
Panning Issues with Pro Tools LE 8 aarborn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-07-2013 04:10 PM
Panning Issues with pro tools 10 clubbersguide84 Pro Tools 10 4 02-05-2012 04:45 PM
Hard Panning Issues in PT LE linderefter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-13-2011 08:31 PM
Panning Issues Jonesies1 Pro Tools 9 6 11-20-2010 07:07 PM
