Problem- During Bounce to disk everything stops
Everything stops and I get a strange looping sound thru the speaks.... And I see an error that says "Overloading CPU. Check for compatiable disk drivers, and try the following: remove RTAS Plug-ins, increase "H/W Buffer Size" in the playback Engine dialog, or thin automation. (-6031)
I have a dual 2.0 G5 set to 99% and a buffer of 512. Not too many plugs going on. It seems I get better on my 002 with LE.... I thought the HD3 accel could handle a little more than what I using. When I look at the system usage, It looks like I usung alot with Reverb One and SAnsamp, but not all the chips are even being hit with anything... I think it said like 75 of 512 or something... I can stop the bounce, save my session and restart Protools and then bounce without issue. Should I be calling Digi? Thanks!
G5 Quad 2.5 Digi 002 G5 D 2.0 HD 3 Accel Control 24 - (2)192's |
Re: Problem- During Bounce to disk everything stops
You need to double check all this is set up right --
-Energy Saver control panel is Enabled, but set to NEVER. -Set Disk Cache is at 512k -Set DAE playback buffer to 2 or 4. -Increase CPU Usage to maximum setting. (but you say you already did this) -Set HW Buffer to 1024 during playback -- (I know default is usually better, but in this instance, try this setting) Also, **For greatest plug-in efficiency place the effects on Aux Inputs and assign Sends on Audio Tracks to route signal through the plug-in that is on the Aux track.** It also may just be the session is PACKED with automation. If so. What you are doing is just fine. (about stoping, saving, and restarting, and having everything work from there) -- Quoted from Digi : "If you encounter a -6031 error while playing back a session with especially dense MIDI or automation, stop playback, save and close the session, quit and re-launch Pro Tools, and re-open the session before resuming playback." Hope This Helps-- |
A Problem with Bounce to Disk | Lasair Dhubh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-05-2009 07:48 AM |
bounce to disk problem | Ijahru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-14-2008 12:55 PM |
bounce to disk problem | Dennis Ferry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-11-2006 05:49 AM |
bounce to disk problem | toadiesXJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-08-2002 04:12 PM |
What stops Bounce to Disk? | SteveGarman | Pro Tools TDM Systems (Mac) | 4 | 03-09-2002 02:23 PM |
