Please help clients will be back in 30 minutes!!!
I have just got a new client group and they are dropping some big doe to record but I am a little nervous because they are use to going to a bigger studio, and i dont want to dissappoint them and to top it off they have already dropped about $4000.00 in cash. I am still new to protools and come from a Nuendo system, which I know like the back of my hand, but they want to record in PT and PT only!!!! Need assistance on setting up a 3 seperate headphone mix with 002? Need one with drums only, 2nd with drums and bass gutair and the last to play all instruments and vox but she need to monitor with reverb but does not want it to record to tape? Need to record all three simoutaneous but each singer has differeent request for head mixes. Please help clients will be back in 30 minutess from a lunch break!!!!! |
Re: Please help clients will be back in 30 minutes!!!
get a headphone amp. Connect it to an output. Then setup a send on every channel to that output. Make sure yoiu set the sends postfader, and that you open them.....
What's that? - That's the machine that goes "pling". Bastiaan |
How many physical inputs and outputs do you have? Do you have a Mackie mixer (or something similar)? Can you get a Furman HDS-6 system at Guitar Center while they're at lunch?
Cue sends (for headphones) are usually PRE fader. How many headphone amps or two track devices with headphone outputs do you own? Do you need to work in Low Latency Mode or not? Rail
I have a head amp, that takes 4 imputs but how do i get it to set up the 3 head mix in prottools and out them to the amp. I have connect them 1/4 inches from the 002 (ouuts 3-6) to the amp (1-4)
lower the latency the better
What make and model headphone amplifier?
BTW - for the future.. buy the Furman HDS-6 My question about Low Latency Mode.. will effect if you can use Aux inputs. Can you record as many tracks as you need without LLM enabled with your buffer set low enough? When you create a send as I explained in my other thread for reverb.. instead of choosing a Buss.. select an unused Output... then feed that to the input of your amplifier(s). Rail
hr6
I only need to record about 3-6 at once, no problem with latenvcy yet, and I havent been using LLM, do I need to |
I suggest a bit of honesty with your clients as well. It will pay off in the long run. |
Rail
Not sure if it will help ya, but I have a diagram on my HELP section on my website. Look below, and click on help button (top right) you will see it on the page at the bottom.
Good luck! -Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
Pt sessions & clients | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-26-2011 08:25 AM |
FW hd's for clients | DHS | Pro Tools TDM Systems (Mac) | 9 | 11-22-2003 11:01 PM |
Getting New Clients | All Ears | Post - Surround - Video | 0 | 01-05-2003 07:55 PM |
PTLE play back problem - possible loss of clients... | gabadilla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-21-2002 01:30 PM |
Best way to get rid of bad clients | Last | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-19-2002 12:42 AM |
