Old 02-26-2014, 04:19 PM
kelco83's Avatar
kelco83 kelco83 is offline
Default Protools completely jacked my new computer
windows 8.1, fresh install of pro tools 11
Computer has been flawless for weeks since I got it. The first ever crash on my computer was installing pro tools 11, BSOD.
The boot was 7 seconds, after installing protools 11 the boot is now 20 seconds and the login is sluggish.
I've got to say, this will be the last version I buy. Software that costs this much should not be this bad. Hire some more programmers or pull the windows version, it is an embarrassment.
Intel 4770K Hackintosh 16GB 128 SSD 770 GTX PT10 11 rack
Mac mini ivy bridge i5, apogee quartet, PT10, 11 rack
Old 02-26-2014, 05:20 PM
mesaone mesaone is offline
Default Re: Protools completely jacked my new computer
And you're absolutely sure that this wasn't user error? Make sure you follow all the optimization steps.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 02-26-2014, 05:42 PM
Sounds more like user error than PT error. I sincerely doubt your boot was 7 seconds before and after installing PT11 it's now 20 seconds. Either way that's a fast boot time. What do you need a login for if it's a single user machine?
Did you do the proper optimizations? BSOD's are rarely the fault of a program but more likely a driver is giving you problems. What's your system setup like? A Sandra report would help a lot.
PT11 is running just fine on Windows for a lot of people so it must be something on your system causing the faults.
Jack
QAPLA!
Old 02-26-2014, 05:50 PM
junkgear's Avatar
junkgear junkgear is offline
I agree with the others. PT 11 is running great on my Win 8.1 system. No crashes, great performance and installing PT did not affect my Windows experience at all.
Will
System Details
Old 02-26-2014, 07:26 PM
The Weed's Avatar
The Weed The Weed is offline
Same for me.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-26-2014, 09:27 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
The computer optimizations that folks are talking about can be found in the Other Resources section of the forum, linked at the top:
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Bruce Paine
System Details
Old 02-27-2014, 09:04 AM
kelco83's Avatar
Ive done all the steps included in the downloadable guide.
Yes, the computer is that fast. Or atleast, it was.
I don't need a gang of sycophants browbeating their denial onto me.
The windows 8.1 version of pt 11 is awful.
Old 02-27-2014, 09:50 AM
junkgear's Avatar
No one is trying to browbeat you into denial, we are simply here to try and help you get your system running properly.
Like stated above, there are plenty of of Windows 8.1 systems out there that are running PT 11 without issue.
If you post more details about your system, perhaps the forum can help you pinpoint the source of of the issues.
As far as boot times, you can run a tool such as AutoRuns to see what is loading when the computer is switched on. It would be best to uninstall PT or go to a recovery point before PT so that your computer is booting quickly again. Then run AutoRuns and take note of what is loading. Then install your driver for your audio interface and do the same thing, then PT and ..... you get the idea. Doing in it small steps will help you find the culprit of your boot time issues.
Autoruns for Windows
Will
System Details
Old 02-27-2014, 12:14 PM
Slower boot times now suggests the registry is full of some bad leftover stuff from a botched install. I would uninstall PT and then run a registry cleaner(or do it manually if you have the guts). This is another instance when drive imaging would have(could have) saved your bacon. I save a drive image BEFORE I install anything(even so much as an update). Resotring to an image that was done when things were all good, is the fastest way to get back to that point
Old 02-27-2014, 12:56 PM
sw rec sw rec is offline
I would be interested to see a Sandra report on this "brand new computer." Brand new doesn't necessarily translate to Pro Tools Compatible.
Computer freezes completely dkroger Pro Tools TDM Systems (Mac) 10 12-10-2010 09:25 AM
computer completely frozen wedgewedge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-03-2007 12:59 PM
Help-ProTools is jacked after new monitor install VanDerGraf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-23-2006 09:34 AM
Protools LE completely useless to me now. vseus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-15-2006 01:42 AM
Completely OT: help with my computer graphics?? murph16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-26-2003 11:21 AM
