Motor Mix & 5.1 -not working
Is anyone else having problems getting motor mix to work with 5.1? I'm getting the "Pro Tools is not communicating...." dialog box. There seems to be some communication happening but not enough to be functional. I've set up the peripherals box for motormix and of course OMS as well. Like I said, there does seem to be some communication -motormixes faders jump to a position when I open a session but from there things immediately stop and the dialog box comes up. This worked yesterday with v5.0.
Any suggestions? |
Re: Motor Mix & 5.1 -not working
I had the same problem. Go under MIDI and choose Input Devices. Select the Motor Mix and anything else you will be using. You should be ok from there. Hope this is the answer.
Take it easy, Steve |
I've had similar problems and the usual fix has been to make a new OMS Studio Setup.
------------------ Larry Bentley Cellar Dweller Productions www.cellardweller.com
Larry Cellar Dweller Productions PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24 Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2 |
Thanks so much spandol! It was a simple mistake of forgetting to enable the Motor Mix as an Input Device. Everything is working now...never mind!
Help Needed with Getting 2 motor mixes working | Notefarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-06-2003 05:58 AM |
I'm using the O1V as a motor mix but... | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-18-2001 01:31 PM |
001 and motor mix | Notefarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-08-2001 09:35 AM |
Anybody working fine with the Motor mixer??? with the Digi001 | executive_chu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-21-2001 01:50 PM |
5.0 & Motor Mix? | skillsaw | Tips & Tricks | 1 | 04-28-2000 07:30 PM |
