Old 07-28-2022, 09:04 PM
Default Pro Tools 2022.7 is out now
I just downloaded it but have not installed yet. I'm finishing a small project first so I didn't want to introduce a new version yet. I'm still on 2022.5.
Any reports of issues? I know the MIDI bugs in 2022.6 were supposed to be fixed with this release.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 07-28-2022, 10:29 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Protools 2022.7 is out now.
Not fixed. Maybe it's even worse now.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 07-28-2022, 11:59 PM
ejsongs ejsongs is offline
How are things worse?
Old 07-29-2022, 03:15 AM
lesbrunn's Avatar
I didn't try 2022.6 because of the MIDI bug reports, so maybe its not really worse. I don't want to hijack this thread, so I've started another one with what I discovered. Please take a look at that...
Old 07-29-2022, 03:39 AM
Emi's Avatar
Emi Emi is offline
They fix things and they breake others...man....
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 07-29-2022, 03:46 AM
lesbrunn's Avatar
Can we call that 'Pro'?
Old 07-29-2022, 04:02 AM
nothing is posted. please elaborate.
thanks,
ej
Old 07-30-2022, 04:02 AM
lesbrunn's Avatar
Originally Posted by take77 View Post
After doing some tests in 2022.7 with both a previous session and a brand new session, I can say that I wasn't able to repro any of the odd MIDI behavior in the brand new session.
However, when conducting tests in a previous session (2022.6) with MIDI imported from a previous version, I can repro bugs right off.*
So I think the new MIDI engine just doesn't coincide with previous MIDI session data?
I did all kinds of tests in the new session. I even quantized a bunch of clips on various instrument tracks all crazy, inserted random tempos and cut & insert time.
All of which I can't do in sessions with PREVIOUS MIDI data.
I will add that I was in grid mode and that none of the MIDI clips were recorded into PT.
For my test I just dragged n dropped a bunch of drum loops on multiple tracks and manually created odd patterns in the editor.
Carried out a bunch of test tasks with quantize & velocity, duplicating, consolidating, trimming splitting clips, Alt + dragging clips etc
My session test in 2022.7 was also at a 44.1kHz sample rate.
And my instrument tracks were in tick mode and the Master fader and main timeline at the default sample mode.
*The very first test in 2022.7 that failed when opening PREVIOUS MIDI session data:
I simply selected a random clip from the timeline (4 Instrument tracks active).
Then Alt+click & dragged the clip across the timeline.
As I dragged the clip down the timeline I watched the green length indicator change from 8 bars to 7 (& some change) as I dragged it across the timeline. And sure enough, when the sample rounding issue occurred, so did the unable to select MIDI notes issue.
But only with MIDI data from a previous version was I able to repro.
The newly created session in 2022.7 enabled me to do my usual tasks and carry out these tasks to an extreme. Randomly modifying MIDI clips on every tack.
After which I was able to drag random clips across the timeline with no change in the length indicator.
No issues selecting, trimming note lengths or cutting & inserting so far in a new session.
So the MIDI has to be created fresh in 2022.7 for me to work unhindered.
Thanks for the info from your extensive testing. There's something I'd to ask: Apart from the midi stuff is there anything different in 22.6/22.7 from 22.5?
Old 07-30-2022, 09:08 AM
JingleDjango JingleDjango is offline
Any reports from users still running Mojave?
Old 07-30-2022, 09:12 AM
off the wall's Avatar
off the wall off the wall is offline
I really don’t use MIDI much at all but 2022.7 is running fine with large sessions with video on my system.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Pro Tools 2022.6 won't launch Scheak80 Windows 5 07-27-2022 09:15 AM
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
MP3 Conversion Quality with Pro Tools 2022 x Pro Tools HD10.3.10 Alécio Costa Pro Tools 4 06-01-2022 11:58 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
Pro Tools Subforum - 2022 or ? Tweakhead General Discussion 22 05-02-2022 12:35 PM
