Old 08-28-2007, 12:24 AM
JorgV JorgV is offline
Default TL Space - Can\'t install TLS IR-packages
I just bought TL-space, but I can't seem to install any additional IR-packages. The pre-installed IRs work fine. I'm quite sure I follow the right procedure: Install TL-space, download IR-packages from digi's website, select 'install IR package' from TL-Space's menu, select a TLS file (TLspace nicely displays a file list for the TLS), click install. When I click the install button, nothing happens. No error message, nothing. The install box just disappears and installs nothing.
Anyone seen this happening and has a solution?
(WindowsXP, Mbox2, PTLE 7.3cs3)
Old 10-02-2007, 05:24 AM
SteveFireland SteveFireland is offline
Default Re: TL Space - Can\'t install TLS IR-packages
I'm seeing this exact same problem - what am I doing wrong?!
Cheers,
Steve.
http://www.stormzone.tv
Old 10-02-2007, 10:01 AM
DigiTechSupt's Avatar
It seems there's a problem with the 7.4 IR installer - we're looking into it.
For now, the workaround is:
Uninstall Version 7.4
Download Version 1.1.2r6
Install your IRs
Uninstall v1.1.2r6
Reinstall 7.4
Avid Audio Tech Support
Support FAQ
Old 10-03-2007, 01:03 AM
Brilliant! Worked a treat. Thanks for the reply...
Anyone know if there's a smart way to import a load of tls files at once rather than one by one, like what I resorted to?
Cheers,
Steve.
Old 10-03-2007, 07:07 PM
x9blade x9blade is offline
that did the trick for me as well. thanks digi
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 10-05-2007, 01:25 AM
gerax gerax is offline
Hello
What about the images of the standard IR package that came with the Music Toolkit? I installed it and everything went fine but I cannot see the pictures of the acoustic spaces sampled...I tried to drop a .jpeg file in each folder but it doesn't work; I did the same thing with the imported impulses, and the images load up fine...where's the trick?
Thank You
L.G.
Old 10-16-2007, 10:41 AM
WKG WKG is offline
Install your IRs
Uninstall v1.1.2r6
Reinstall 7.4
Any news on the buggo 7.4 installer yet?
After the update TL Space is now eating my CPU for lunch.
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6
RME, Daking, Heritage, ISA, Sytek
Old 10-17-2007, 10:29 AM
Eway Eway is offline
Hello,
Even doing the workaround I still have the same message "One or more files were not written. Please check log for errors".
What can I do to get those packages installed ?
Thanks
Old 10-17-2007, 10:56 AM
For that I have the answer... First You'll have to extend the window's Plug by pushing the >> symbol. Click on edit (hold) ==> import other IR folder. Choose the folder where the Ir are installed (Program files\common files\Trilliumlane\Tlspace\impulse response) Then you'll see the photos with your selected IR. Plus you'll have now much more presets. Take a look by yourself ..
Old 10-18-2007, 01:22 AM
AAAhhhhh!! I tried it. It worked. Great, many thanx for sharing
L.G.
How to do I install SPACE IRs evilstudios AAX Plug-ins 10 11-11-2014 12:50 PM
TL Space IR install problems John King macOS 9 11-21-2012 12:51 PM
How Much HDD Space Is Used To Install Pro Tools 7.4 ? regularcat Pro Tools TDM Systems (Win) 2 11-02-2010 08:44 AM
Tl space ir's and pt8,cannot install Maddawg383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 09-01-2009 03:14 PM
TL Space IR packages sunking3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-17-2009 11:57 AM
