Moving 001 to new G4
I've used Digi001 and ProTools LE 5.1.1 for over a year on a G4. I've just bought a new G4 for my studio and I want to move the PCI card, DIgi001 box and Protools software (application, system files and datafiles) to the new G4 by copying all the software to a CD (from the old G4) and loading it up on the new G4. Can do? Or do I have to do a clean install
Re: Moving 001 to new G4
It's much safer to reinstall, unless you're a mac expert. You need to really know what you're doing to do it this way. When I got my new G4, I connected the 2 computers via appletalk and copied all my software, but you need to go into the system folder and get all the prefs and extensions and control panels. as well as all the DAE stuff. I ended up only having to reinstall my OMS and my SoftSample Cell, but it was a lot of work.
Build it from scratch! And set at least a day or two aside for the work. If you go the other way, you should have the rest of the week off.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
just a suggestion, but did you try connecting them via ethernet or fw (target disk mode) and copying the system drive over onto the new machine?
Or better yet, take the old system drive, remove it, install as the master in the new machine, and make the new machines hard drive a slave to your old one? (confusing?) Basically use the newr mac's drive as a second drive, and put the old drive in it's place... |
[img]images/icons/shocked.gif[/img] |
[img]images/icons/shocked.gif[/img] <hr /></blockquote><font size="2" face="Verdana, Arial">Actually it is just that simple. Simply remove both ATA bus 1 master drives from each computer and swap them. the new machine will hav ethe old machines OS and apps on it now. You can also via ethernet/appletalk copy the apps and preferences over. In fact, you can copy the entire hard drive to the new computer if you wish, and have a mirror image of the old machine. Copy Agent is superb for doing this, as it will copy all hidden folders and files that sometimes do not get copied via Mac OS. If you have not been experiencing any problems with your current PT set-up, this would be an excellent and fast way to get your current set-up on to your new machine. Hope this is helpful. |
Will this also copy over challenge/response codes and/or other authorizations, Digi plugin auths for Maxim, for instance?
Fear of having to get all new copy protection codes for the dozens of copy protected software I have is one thing holding me back - and considering CPU upgrades instead. $$$ is the other [img]images/icons/wink.gif[/img] .
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Thanks Where,
I don't even need to reply to the poster who said it isn't that simple!!! [img]images/icons/wink.gif[/img] |
Except that a G4/400 and a g4/800 may have potentially different hard disk drivers/firmware. If you have an old hard disk driver installed on your 400 and plop it into newer firmware... You never know.
I agree it is quite possible, but I still say unless you're used to troubleshooting, it's better to do a clean install. Whatever you do, and this goes without saying, make sure you do a full backup of your existing drive before you move anything. |
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
Moving to MAC | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-12-2006 08:35 PM |
Moving right along | taylormayd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-02-2004 01:23 AM |
Moving from DP3 | schuey100 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2003 05:18 AM |
Moving up, but how far...? | Jessariah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-29-2001 11:52 AM |
