Old 02-17-2018, 09:24 PM
LeoVilla LeoVilla is offline
Default Unable to set inputs on the I/O section
Hi, I'm currently unable to set inputs on the I/O section, I'm trying to set a path for my focusrite 2i2 on Pro Tools 12.8.2 but even though I used my set up options, Hardware, Playback Engine to set my interface, the I/O section specifically the input section doesn't allow me to create new paths, all of the options stand grayed. Can you help me?
Old 02-17-2018, 09:41 PM
Hi welcome to DUC
What OS version are you using?
You are trying to create an input or output or bus path?
You are absolutely sure the correct playback engine is selected? (what exactly does it say?)
I recall there was a problem with the 2i2 only showing up as discrete input or output devices. What does Audio Midi setup show you? Do you see two devices? If so you can create an aggregate device in audio midi setup and then use that as the playback engine. You can also search for older posts here about that or contact Focusrite support... that one is their bug.
In the IO input/bus/output on each page delete all paths showing there and click the default button.
Old 02-17-2018, 11:09 PM
Default Re: Unable to set inputs on the I/O section
It was a problem With the MIDI section, I finally got to start recording, thank you for your reply, it helped a lot :)
Is it possible to rename the source inputs in the monitor section? stefanboman Avid S4/S6 4 03-23-2017 06:20 AM
Mbox2 Pro - unable to hear inputs without having PT on cosmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-25-2012 06:05 AM
Unable to use Virtual Instrument Inputs and Outputs dbonney Virtual Instruments 1 05-23-2011 10:50 AM
Unable to view (or select) all 4 Inputs in Pro Tools I/O halljr1 Pro Tools M-Powered (Mac) 1 11-27-2007 07:34 PM
i/o port Under the monitor section inputs and outputs rorytherhino ICON & C|24 1 04-14-2007 05:16 AM
