Old 05-22-2011, 09:08 PM
dbonney dbonney is offline
Angry Unable to use Virtual Instrument Inputs and Outputs
I had Pro Tools 9.0.0 and all of my MIDI was working perfectly, midi controller and all. I installed the update to Pro Tools 9.0.2 and now none of my MIDI works. When I go into the instruments inputs and outputs in the mix window, none of my virtual instrument In's and Outs are even available in the drop down menus. The only thing that shows up are hardware outputs from my interface and from my MIDI Controller. I un-installed everything 9.0.2, re-installed 9.0.0 and the same problem persists. I can not use any midi at all. Please Help.......
Old 05-23-2011, 10:50 AM
spenner spenner is offline
Default Re: Unable to use Virtual Instrument Inputs and Outputs
Could be a corrupt download. I'd download the 9.0.2 update again using the Download Manager.
Inputs/outputs Garitt87 Pro Tools 10 1 07-15-2013 01:40 PM
X-Mon Inputs-Outputs tico ICON & C|24 14 03-21-2013 06:19 AM
Inputs and Outputs PUMASALAD macOS 2 04-28-2011 02:47 AM
Unable to audition any virtual instrument js1 Virtual Instruments 5 06-15-2006 05:49 PM
can't use inputs 1 and 2 because same as outputs wigglemeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-08-2004 10:32 PM
