Old 07-13-2009, 07:41 AM
15th SINE 15th SINE is offline
Angry Constant Clock & 6086 errors WHY? WHY? Digidesign PLEASE Answer
Hi I recently upgraded my rig to Digi 003 Rack Factory with Pro Tools LE 8.0
Loving new features of Pro Tools, but constant errors keep coming up forcing me to save , shutdown my computer then boot up everything again ggggrrr.
Errors including are the following:
1. The Operating System held off interrupts for too long. If this occurs frequently, try increasing the “H/W Buffer Size” in the Playback Engine (-6086)
2. Problem detected with audio clock. Check that your clock source and sample rate are correct.
3. Pro Tools cannot communicate with 003. Please reconnect the unit and press ok. (Umm ok I NEVER touched the Power button, power plug or firewire cable.)
4. Audio Engine play startup deadline was missed.
I never got these sought of errors on my Digi 001. Here’s my current playback engine setup, tell me if it’s ok or tell me a better one.
H/W Buffer Size: 1024
RTAS Processors: 2 Processors
CPU Usage Limit: 85 %
DAE Playback Buffer
Size: Level 2 Cache Size: Normal
Or does my System PC Suck and has issues with it. PLEASE help me
PC – Windows XP PRO SP3, 32 bit
4gig RAM (DDR1)
Gigabyte 8IPE775P Motherboard
Intel i865PE Chipset
Intel Pentium 4, 530J CPU (3Gig) – (1 Physical Processor / 1 Core / 2 Logical Processors)
Gigabyte Radeon 9250 Video Card (128 mb total memory)
C: Drive for programs 80 gig Seagate , E: Drive for Audio 160 gig Seagate
Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Old 07-13-2009, 12:08 PM
sw rec sw rec is offline
Default Re: Constant Clock & 6086 errors WHY? WHY? Digidesign PLEASE Answer
Hmmm....my only thought would be that a Pentium 4 isn't much horsepower for the newer software. I ran my old 001 on one and got along fine with up to about 6.1, but wouldn't think there's enough resources to run 8.
Clocking...have your sync source set to internal or external?
Old 07-13-2009, 12:10 PM
TOM@METRO's Avatar
My first thought is one you are not gonna' like. Your system is not strong enough to run PT8 well. That being said, if you want to proceed to try to get out of it what you can, then first post a Sandra report. Instructions are here.
EDIT: Have you tried more than one firewire port and cable?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 07-13-2009, 12:15 PM
While you're doing that, remember to NEVER hot-swap a firewire cable.
"WHY? WHY? Digidesign PLEASE Answer"
This is a USERS forum, but they might chime in from time to time......
Old 07-13-2009, 07:31 PM
pianosound pianosound is offline
+1 on a weak system!!! My P4 got me to PT 6.4,,, sort of,,, had to upgrade in order to use PT 8!
Sorry man,,, good luck,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 07-13-2009, 07:42 PM
Jenk2k Jenk2k is offline
You should roll back to an earlier version of Pro Tools. You can get alot done in 7.4 with a system like that.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 07-13-2009, 08:35 PM
but i thought my system is fast yea always new technology you must upgrade asap
my clock source is set to "Internal"
Would getting a new Firewire PCI card & Cable do the trick ?
i have another PC which is newer i just use for the net thing is its Vista
i could Roll it back to XP Pro and add more Ram heres the specs on my other one, tell me if its any good and if it get rid of all these errors
Accer 1640
Windows Vista Home Premium SP1
3 Gig RAM – DDR2 – SDRAM
NVIDIA MCP73 Motherboard
NVIDIA GeForce 7050 Chipset
Intel Pentium Dual CPU E2160 (1.80GHz) – (1 Physical Processors, 2 Cores, 2 Logical Processors/64 bit)
NVIDIA GeForce 7100 / NVIDIA nForce 620i Video Card (256 mb Total Memory)
C: Drive for programs Hitachi 74 gig D: drive for Audio Hitachi 74 gig
VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller (Fire Wire port)
Old 07-13-2009, 10:00 PM
TOM@METRO's Avatar
In a word... NO.
The Intel CPU and the Nvidia chipset together are known to be problematic with Pro Tools.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 07-13-2009, 10:59 PM
So now i have to buy / build a new PC to over come this were can i find ideal specs for PC , i want the next one to be a Quadcore im so angry now. o well i think i can hold off a bit and put up with run errors.
Old 07-14-2009, 03:10 AM
TOM@METRO's Avatar
You can still post a Sandra report and see if there is some way to improve things inexpensively.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
(-9092) (-6086) constant errors, please help me fix this klaveman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2011 08:42 PM
Constant 6086 error on ASUS laptop PT8 AnalogueRazor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-09-2009 11:42 AM
Bogged down by constant 6086 HW Buffer errors since Upgrade mike2150337 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-09-2007 09:29 AM
Constant 9129 and 6086 error messages Aussie Adam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-07-2004 08:48 AM
Constant H/W buffer errors. - 6086 & -9129 Aussie Adam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-21-2004 03:03 PM
