humm
does anyine have a problem with electrical hum in you're monitors?
it is not verry loud, does pt do this or is it another problem. i've removed all the dimmers and balaists in the house. i separated my power and audio cables from each other. and my gear is on an isolated breaker from the rest of the house. i do have the power cables zip tied together for neatness. can this cause hum? please help!!!???!! thx jay
athlon 3200 gigabyte an7 1024 ram 001 |
Re: humm
if these are powered monitors, are you using balanced (i.e., 1/4" TRS) cables to them? if not, you may get that hum. tying the power cables to an unbalanced cables (i.e. 1/4" TS) may induce a 60Hz hum also.
Pro Tools 2022.9 UAD Apollo 16 (v10.1) Dell XPS 8940 (i5-11400) Win10 www.studiodrumtracks.com www.doubledogrecording.com |
Re: humm
Try AC ground lifters on your monitors. If this solves the problem, you have a ground loop. The correct way to fix it(do not leave the AC "cheaters" in place) is to clip the sheild connection at the monitor end of your balanced cables(going from your DIGI interface to your monitors).
Mic Humm | Earl D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-10-2006 06:01 PM |
Speakers constantly humm | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 11-29-2003 11:36 AM |
monitor humm... | metaltim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-09-2002 12:10 AM |
equipment humm | freakuincy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-12-2002 09:57 PM |
50hz humm/control24 | Tom_Weber | ICON & C|24 | 1 | 07-03-2001 09:44 PM |
