Old 10-11-2015, 08:54 PM
mikegahan0 mikegahan0 is offline
Default Help with Soundcraft board!
hey guys, This is my First post on the board so I appologize if the thread is in the wrong place but i need some help.
Recently, I bought the new soundcraft board (si impact)*so pretty i know*
and it has a 32 x 32 i/o that I have gotten to work with my pro tools 12 system however, at seemingly random times, I get this pesky 9129 error saying
" Audio process could not be complete due to CPU issues....this could be a H/W buffer issue or clocking...."
Ive been fighting with this for a while and have tried everything:
tried all the h/w buffer sizes
closing other processes
puting the boards clock source to external and turning on MTC
Tried other DAWS (ablton live lite, fl studio, cubase) all work fine
the drive with screen shots of my errors and task manager
https://drive.google.com/folderview?...UU&usp=sharing
specs of computer:
intel i5-4960k @ 3.5ghz
8gb ram
windows 7 service pack 1
again PLEASE HELP THANKS!
Old 10-12-2015, 07:39 AM
john1192 john1192 is offline
Default Re: Help with Soundcraft board!
your link shows like this ..
File Type: png Screen Shot 2015-10-12 at 7.37.47 AM.png (94.2 KB, 0 views)
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-12-2015, 08:44 AM
sw rec sw rec is online now
i5 processors haven't been giving stellar performance with Pro Tools, and 8gb of ram is a little on the short side as well. I'd highly recommend following the "help us help you" link and post a sandra report so we can get a better idea of what we're dealing with.
Old 10-12-2015, 11:44 AM
Before i got the board I had no problem running pt. I dont understand why pt just cant channel audio through the interface without crashing.
Im working on getting the pictures up.
Old 10-12-2015, 11:49 AM
https://drive.google.com/folder/d/0B...pmb0R6TUU/edit
Try this one
Old 10-12-2015, 12:04 PM
Guess that depends on what your interface was before.
Old 10-12-2015, 12:12 PM
That would be the akai pro EIE using asio4ALL driver. Now using the soundcraft asio driver
Old 10-20-2016, 01:37 AM
SteveHornblow SteveHornblow is offline
Hi there, I've also got an SI impact and I can't work out how to route audio out of protools into the SI Impact. I set a channel in the desk to receive via MADI USB Combo card channel x (same as sending out of pro tools) but no sound ....
Old 05-07-2017, 10:39 AM
Jaytm401 Jaytm401 is offline
I found a useful video on YouTube. This may help you. https://www.youtube.com/watch?v=GMgqbufzbug
Also you want to make sure in you install the Soundcraft drivers for you board on your computer. ONce the drivers have been installed then you will need to go into the Soundcraft USB Audio Control Panel (software that is installed for the drivers). You will need to setup the Buffer Settings to match Protools. I am using ASIO Buffer Size 64 Samples in both Protools and the Si Control Panel configuration. It was a quick and dirty setup with no research or jedi mind control. You will also need to setup your I/O on each channel/track.
I hope this helped you. Now my only problem is, I am trying to playback the live recordings I just did back to the SI impact Mains. If you figure this out, please let me know. Thanks in advance !
Old 09-18-2021, 12:17 AM
IanSylvester IanSylvester is offline
Jaytm401, if you want to send audio through outputs 1 & 2 from the Daw to the mixer, you should select the Inputs on one of your stereo channels to be outputs 1 & 2 from the MADI card.
Digi C-24 or Soundcraft [email protected] Pro Tools 10 6 06-04-2014 09:24 AM
BOARD TECH NEEDED to service Amek Matchless board audio[LAB] General Discussion 4 01-31-2007 11:17 AM
Soundcraft Inserts Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-16-2005 07:45 AM
AH mix wizard VS Soundcraft M12 jkung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-17-2003 11:59 AM
Soundcraft Spirit 328 Plugs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-07-2001 10:46 AM
