Old 01-18-2011, 10:41 PM
Oakdale Post Oakdale Post is offline
Default New Session From Template in PT 8.0.4cs2
I am new to PT 8 and have been reading about creating new sessions from templates. I know you can specify sample rate, bit depth and file type in the open from template dialog.
Can you also specify (within the template itself) sync source, session start time and frame rate?
I bounce between sync source internal at 30fpsndf and sync source Sync I/O referenced to Black Burst (video ref) at 29.97ndf or 23.976. Also, the session start times change from 00:00:00:00 and 00:59:00:00 respectively.
Alternatively, is there a way to achieve this from the Open Session from Template dialog that I'm missing?
Madness does not always scream at you... sometimes it's the quiet voice in your head that asks "Hey is there room in there for one more?"
HDX 10.1 (2 Cards)
Mac Pro 8 Core 2.4Ghz Westmere 26 gig Ram
Icon D-Control, Two 192HD 16x16 analog and 8x8x8 Avid Mojo, Sync HDI/O
Old 01-19-2011, 01:44 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: New Session From Template in PT 8.0.4cs2
This is really easy to test! load a session and set it up as you want it. now save it from the file menu as a template. now close PT completely to be safe it works, now re boot PT and open the newly saved template and see if all your settings have stuck.
whilst opening the template it will ask you to save the session with a new name of course as this is a template its expecting you to be saving a new session!!!
Viva Las Vegas
Chris
Producer, Engineer,
www.ukmastering.com
Importing a mix session template into a record edit session bryced87 macOS 1 04-27-2012 04:24 AM
Session file load freeze PT 8.0.4cs2 on XP mikey55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-01-2011 10:57 AM
session template HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-04-2010 11:58 AM
How...Create New session with Session Template TDelmar Tips & Tricks 5 10-22-2008 08:29 PM
How Do I Re-Use Template For New Session cooks95 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-30-2005 01:02 PM
