Old 09-27-2013, 10:47 AM
garnoil garnoil is offline
Default PT 11 HD with HDX plugins not showing up
Today I upgraded from TDM accel to HDX. Now running Pro-Tools HD with HDX dual version 10.3.7 and 11.2. Pro-Tools 10.3.7 appears to be ok all plugins show up. Pro-Tools 11.2 NO 3th party plugins show up at all.
I found this on the DUC (is this the way to get the 3 party plugins to show up?):
Inside the Pro Tools 11 application package, there is a folder labeled "Core Plugins". When I put the plugins in there, all worked perfectly.
Thank you
Old 09-27-2013, 10:51 AM
Drew Mazurek's Avatar
Default Re: PT 11 HD with HDX plugins not showing up
Are you sure your 3rd party plugs are AAX64 ready? And you've installed the newest versions?
www.drewmazurek.com
Old 09-27-2013, 11:33 AM
I think so but I will double check. The dialogue that appears at the start of PT 11 shows thsese plugs that are not up do date: Equality, Izotope, Spanner, PsP Echo and Nugen ISL (I will update these plugs but I thought I had already updated equality and PSP Echo).
But what about CEDAR studio, I have the latest version of CEDAR and it does not show up. Also Liquid Sonics Reverb (is AAX it should load)
Old 09-27-2013, 12:00 PM
Not just AAX, but AAX 64 bit with support for PT11.
This might help as well.
http://www.pro-tools-expert.com/aax-database/
www.drewmazurek.com
Old 09-27-2013, 02:52 PM
thank you, I upgraded Equality and Liquid Sonics (these two are now working). CEDAR should have work as I have the latest version (I am contacting support at CEDAR). I have a few more to check for upgrades like Izotope and Unveil.
Old 09-27-2013, 06:27 PM
DetroitT's Avatar
DetroitT DetroitT is offline
"Inside the Pro Tools 11 application package, there is a folder labeled "Core Plugins". When I put the plugins in there, all worked perfectly. "
Not the. Correct install location for 3rd party!
Avid in your library, applications support, audio, plug-in is where you should be installing.
If your putting in the applications core then your next update would delete them.
Old 09-27-2013, 08:31 PM
thanks you for that info.
Old 09-28-2013, 04:02 AM
Thanks for all who answered my question. So far NOT a Pro-Tools issue, I needed to upgrade the plugins. I thought that AAX was supposed to work with PT 11, but it has to be AAX for PT 11. The CEDAR studio is NOT ready for PT 11 yet neither is LowEnder. I can not use PT 11 till these 2 plugs are PT 11 compatible.
thanks
New TDM Plugins Not Showing Up SPA Pro Tools TDM Systems (Win) 3 03-01-2010 06:07 PM
Old plugins still showing... digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-14-2009 02:21 AM
Plugins not showing up Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2006 01:58 PM
Plugins not showing up subaro0o 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-10-2006 12:25 PM
TDM Plugins not showing up... JLEpperson Pro Tools TDM Systems (Mac) 0 03-01-2001 02:19 PM
