Old 09-20-2006, 07:32 AM
DOUBLE EDGE DOUBLE EDGE is offline
Default How to calculate Tempo
Whats the easiest way to calculate tempo for a audio file..IE. a 2 track beat?
Thnx
Mac Pro 2.66 - PT 7.3.1 cs2 -
Old 09-20-2006, 08:10 AM
CME CME is offline
Default Re: How to calculate Tempo
There are probably easier ways, but I have an fx processor in my rack with tap tempo. So I tap along and it shows me the tempo. I had never thought about doing that because I usually record my own stuff and sync Reason to Protools for a drums. But I was recording a vocalist the other day to prerecorded tracks. During mixdown I wanted to add some delay, but couldn't figure out the tempo. Then I remembered what the little blinking yellow light on the front of the fx was for. It may not have been perfect, but it was close enough.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 09-20-2006, 08:21 AM
HA, Ive been doing it so long that i just count for 15 seconds the amount of beats than multiply that times 4.. but damn there has to be an easier and more importantly COOLER way..
Old 09-21-2006, 03:33 AM
mindnoise mindnoise is offline
HI,
I thought PT 6.x had a Identify Beat Command and 7.x+ has Beat Detective,
don´t they?
regs
last: PT11.3.1
Old 09-21-2006, 04:59 AM
They do, but i never used them, can you shed some light on it?
Old 09-21-2006, 05:47 AM
can you be more specific? as I won´t read the manual to you
so since I only have 6.4 I am limited to ID Beat anyway but works good for me.
so select Audio Region, set Barmarkers, disable manual midi mode, choose ID Beat,
and set the Beat marker beginning to 1/1/000 and the end to 1/2/000 or 2/1/000 etc. done
Using on seperate reagions builds tempo maps.
regs
last: PT11.3.1
Old 09-21-2006, 11:13 AM
Your soo lazy... i'll try beat detective and see how it works. neways thanks
Old 09-21-2006, 01:33 PM
HI,
at least I gave some hints on ID Beat, which was hard work enough.
you know what Jimi Hendrix replied when he was asked if he works like the usual man of labor
and gets up every day at six in the morning?
He said:I´ll try to get up every day! I couldn´t have said it better!
regs
last: PT11.3.1
Old 09-22-2006, 08:57 PM
gibson_sg gibson_sg is offline
"Your soo lazy" ?
Who's the one who need to do the work to learn the knowledge here?
I thought that was a pretty rude thing to say to someone offering you free advice.
Take it as it is.
Old 09-22-2006, 09:20 PM
jre3132 jre3132 is offline
Thnx
Though I don't usually use the dashboard/widgets, I installed a BPM widget. I just hit play then launch the dashboard (hot corner) and tap the tempo right on the screen.
Very quick and simple.
After I enter the tempo in PT, I move the 2 track on to the grid so I can copy and paste in grid mode.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Calculate tempo does not match tempo ruler sssonic Pro Tools 9 1 11-07-2011 10:34 AM
any way to NOT calculate overviews in PT8? therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-02-2009 03:57 PM
how to calculate the delay of plug-ins? Eddie Eagle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2009 11:07 AM
calculate tempo remix ModaRecords Pro Tools TDM Systems (Mac) 8 03-03-2006 08:48 AM
calculate latency? Lorddiagram 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-06-2005 04:38 PM
