can peak be configured to play back through digi
Do I have to run the stereo outs from the mac to listen to peak? I realize it's going through the asio drivers. Once it been work on and mastered on peak am I not able to listen back through the dae just like when I bounce a file and then burn to toast? I know that I am not really understanding the process
Re: can peak be configured to play back through digi
Yes, you can use digi hardware. I have done this using the ASIO driver. It was awhile ago, let;s see. (i just looked) you select the Audio menu, choose Sound Out, then ASIO driver and you get a window , choose Digi 1 and 2 out and close it. You cannot run Peak and PT simultaneously though.Good luck,
Bruce |
thanks that was clean and simple I'll give it a try
Play back only in one ear | Hambone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-04-2010 05:05 PM |
im not getting it to play back | fallingobject | Pro Tools M-Powered (Win) | 0 | 04-14-2007 05:55 PM |
play back | einstagtor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-28-2005 10:16 AM |
Digital feed back on play back after Bounce | drew88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-12-2005 01:18 PM |
No Play Back | Ecarter | Pro Tools TDM Systems (Mac) | 2 | 07-10-2004 10:23 AM |
