Old 02-02-2023, 09:23 PM
HellOn6Strings HellOn6Strings is offline
Default Aux Sends doubling tracks
So here's my issue and any help would be apreciated! whenever I create and Aux track and then try to send another track to it all it does is double the track. for instance, I set up a reverb send for my vocal but instead of just mixing in the reverb it actually mixes in a doubled vocal track with the effect. it does this in all my sessions now so I can't create any effects sends anymore. I've never had this problem before and I dont understand what's going on. I've been using pro tools for 7 years now and never encountered this!
Old 02-02-2023, 09:38 PM
its2loud its2loud is offline
Default Re: Aux Sends doubling tracks
For the reverb effect you are inserting on the Aux track you need to adjust the Mix parameter in the reverb to 100%. Most plugs default to 50%. This will send 100% of the wet signal through the Aux track to mix with your dry vocal track.
If the plug is anything less that 100% you’ll be sending wet and dry signal through the Aux track. ie, if the plug is at 50% then half will be wet and half will dry signal.
Aux Sends Latency/Doubling Problems_PLEASE HELP!!! ThirdWise Getting Started 1 05-12-2021 12:33 PM
How Many Tracks plus Aux Sends can you have? paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-29-2010 08:54 PM
Printing and doubling tracks--alighnment? ishur Pro Tools TDM Systems (Mac) 12 05-23-2007 05:20 AM
Cannot edit sends on all tracks? jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2002 05:42 AM
Mixer Question - Doubling of tracks citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-04-2002 11:41 PM
