Old 03-19-2024, 04:12 PM
Goombot Goombot is offline
Default Internal renderer live renderers not staying on input
Using ProTools Ultimate. Just switched my workflow from the external renderer to the internal renderer with basically no issues except for the input status of my live rerender tracks is not staying that way once I close and open the session. I have a 7.1.4, a 5.1 and a 2.0 all being monitored on input via live re renders routing to different sources in the DADMan. All those tracks used to stay in input once I closed the session and opened it back up but they do not do that now. My friend confirmed the same thing on a separate rig. This is something that needs to get fixed unless there is some preference in the new PT that I'm not seeing.
Old 03-19-2024, 04:36 PM
its2loud its2loud is offline
Default Re: Internal renderer live renderers not staying on input
This might be a bug, and a good catch if it is. It also might be a safety in case you accidentally route a live re-render back to the renderer. If you're just using the Re-renders for metering the usual use case here is to create an Aux Track and route the Re-render to that Aux with the metering plugin on the Aux.
Old 03-19-2024, 06:24 PM
Right. I thought that. Seems like a bug though. It's definitely moving backwards.
Old 03-21-2024, 09:36 AM
MDGenerato's Avatar
MDGenerato MDGenerato is offline
Hello, David here from the Avid Community. I've gone ahead and created a case for you for our tech team to look at: 04775986. Thank you for spotting.
Old 03-21-2024, 11:58 AM
Great. thanks.
Dolby HRTF w/ Internal Renderer dcoffset Avid Pro Mixing General Discussion 2 03-18-2024 08:37 PM
How to open ADM using the Internal Renderer? rosshc44 Pro Tools 8 03-08-2024 02:50 PM
Internal / External renderer prompt at PT launch mattrixx Post - Surround - Video 3 02-08-2024 04:54 PM
Internal Renderer Uses CPU Resources When Not In Use ZoeMusic Pro Tools 0 01-11-2024 11:56 AM
Internal Renderer 2.0 Re-Render issue paulo m Post - Surround - Video 2 01-04-2024 04:14 PM
