Clearing Unused Audio PT errors ??
Hello,
Is there a known bug with the “clear unused audio” command in the Cliplist? I’m using PT 2024.3 and when I ‘select’ and ‘clear unused audio’ PT looks like it performs the task but when I then “save a copy in” it still makes a copy of the unwanted supposedly ‘cleared’ files as well?? The same problem was happening with PT 2023.12. The only workaround I’ve figured out is after ‘select’ & ‘clearing unused audio’ from the clip list to then create a New Session and import the tracks in and then only the desired audio is imported. Thanks so much... Mac Mini M2 Ventura 13.5.1 PT 2024.3 |
Re: Clearing Unused Audio PT errors ??
Hi, I've just checked and it seems that it happened in the past. Last recorded was with Pro Tools 11 and 12. no further reports on this after. I'll start up a support case for you on this. Thanks
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
started a support case for you under case number 04774385
You'll be contacted via Email. Thanks
Clearing out unused tracks | BLG | Getting Started | 2 | 09-28-2020 02:59 PM |
Unused Files Clearing | Ozman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-30-2008 05:12 PM |
Clearing out unused media in sessions | stanonbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-18-2005 08:00 PM |
Clearing out the unused Audio | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2004 11:58 PM |
Remove versus Delete when it comes to clearing unused audio... help! | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-26-2002 12:19 AM |
