Importing audio extends the audio clip (I checked sample rate)
Hey everyone,
When I import audio clips from ableton into protools they get slightly longer. Everything is 44/24, and I've googled for hours and cannot figure out the problem. When I import into logic everything looks fine. I made a new session and took a screenshot to explain my process: Bounced a clip from ableton in 44/24, 115 bpm. Set PT session to 44/24 and 115 bpm. Imported on two different tracks, one in samples one in ticks. here is timeline: pic Here is import settings: pic I know there can be minute differences in bpm between DAWs but this is just too much. Seems like there's a box somewhere i didn't tick. Just to be clear, this seems like an audio problem. When I export the file, it's longer than the original (and occupies more disk-space) I can make the clips fit the grid with elastic audio turned on, but i'd rather not warp my track, and it has a hard time detecting some the less transient tracks in my session. |
Re: Importing audio extends the audio clip (I checked sample rate)
Page 1112 of the Reference Guide. "Auto Match Pull Factors". Could this setting in your session be causing the problem?
Importing Audio by double clicking a clip defaults to Add | relder17 | Pro Tools 10 | 7 | 09-08-2013 09:29 AM |
command-/alt-plus/minus extends clip to wrong length | Frank Kruse | Post - Surround - Video | 6 | 04-25-2013 06:48 AM |
Frame rate audio clip converter | RuffinMedia | Post - Surround - Video | 3 | 07-04-2012 02:55 AM |
How to get audio from 44k to 22k sample rate?? | ZproGreg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-25-2005 04:34 PM |
Audio Sample Rate Pull Up / Down in 6.4 | James Kellar | Post - Surround - Video | 1 | 08-22-2004 03:37 PM |
