Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 10-11-2012, 05:09 AM
mrussaustin mrussaustin is offline
Default Playback Engine Problem
I have Pro Tools 9, and run Mac OSX 6.8 Macbook Pro. I use a Fast Track Pro as my interface. Initially my session was running fine, with just drums, which I imported from a 16 track. There are about 8 tracks with at least an eq and compressor on each. I started to record bass, but halfway through the play back engine would quit. I disconnected the Fast Track and reconnected it to get sound running, but then when I re-opened the session it happened again. I tried resetting the buffers in the playback engine, but then something worse happened. Now I can't even access the playback engine. A dialogue comes up which says "could not complete playback engine request because volume(-35) was not found. I thought that this might be a laptop problem, so I went to school where they have a very nice system and the same dialogue comes up.
Playback engine support problem... jjtarnow macOS 3 10-19-2014 03:22 PM
PT 9.0.5 Native has problem with playback engine JoeM Pro Tools HDX & HD Native Systems (Mac) 2 12-04-2011 06:08 AM
Playback engine support problem... jjtarnow Pro Tools M-Powered (Mac) 0 01-09-2011 11:18 AM
Playback Engine Problem (-9136) thebends9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-16-2006 11:40 PM
MTC sync / playback engine problem Ulrich Reiter Pro Tools TDM Systems (Mac) 1 02-22-2002 06:49 AM
