Old 10-20-2010, 02:09 PM
paul_g's Avatar
paul_g paul_g is offline
Default Pre Amp question
My Rig:
Intel iMac 2.4g processor 4gb ram, 10.5.8 OS X
Lacie FW 800 drive
Protools 8.0.4 and Factory 003
question: if I purchase this: http://www.presonus.com/products/Det...x?ProductId=13
Will this give me an additional 8 inputs to the 8 I already have on the 003?
Can I simultaneously track 16 tracks?
paul g
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 10-20-2010, 02:21 PM
Ben Jenssen's Avatar
Default Re: Pre Amp question
Yes.
Old 10-20-2010, 02:23 PM
marcioguitar marcioguitar is offline
Originally Posted by paul_g View Post
My Rig:
Lacie FW 800 drive
paul g
yes, it will give you 8 additional tracks over adat connection giving 16 tracks simultaneously.
Old 10-21-2010, 12:16 PM
paul_g's Avatar
One other question:
GC doesn't carry the PreSonus Digimax FS, however they recommended the Focusrite OctoPre MKII.
How do they stack up? I realize Focusrite is pretty high-end... just looking for opinions.
Thanks!
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 10-21-2010, 01:38 PM
That particular Focusrite is not high-end. They are in the same ballpark for sure. Another Presonus product that would also work fine(and cost less) is the D8. I believe its the same preamps, just fewer bells and whistles. Or you can go totally low budget(but still totally usable) with the Behringer ADA8000. For high-end, look at the RME preamps/interfaces or the Focusrite ISA428 or 828 models.
Old 10-21-2010, 02:47 PM
The Dougfather The Dougfather is offline
One other question:
Thanks!
I just got rid of a Focusrite Octopre LE, i'd never liked it from day one. It made everything sound harsh, i mean literally everything, i was constantly compensating with EQ.
The ADA8000 does the job, better than the Octopre but it's nothing special, it's just ok.
I just picked a used Digimax FS and i can't believe i wasted my time on an Octopre, the difference is night and day. The Digimax pre's are tonally well balanced, clear and punchy. You've got insert points for compressors etc if you need it and the DAC. The clocking off this unit is pukka as well.
Just my two pence.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 10-21-2010, 05:05 PM
paul_g's Avatar
Problem w/ the D8 is that it only goes to 48k sample rate.
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 10-21-2010, 05:19 PM
paul_g's Avatar
Just my two pence.
Doug, I see a lot of your posts, so I trust your judgment. This is very good to know. Turns out I found a GC locally that has a PreSonus Digimax FS and I'm about to purchase (plus I have a GC coupon!)
I have (4) PreSonus Tube Pre's and am very happy with them. I use those on for the 4 Line-In's of my 003 (never understood why Digi only gave 4 pre's on 003)...
p
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 10-21-2010, 05:26 PM
Since the 003 only works at 48K thru lightpipe, its not actually a problem. BTW, I would say the vast majority of us in the LE world work at 48K and 44.1K almost all the time. I for one, don't need 96K, especially considering that the bulk of my mixes end up on youtube or myspace as godawful mp3 files Back to the original question, if you need 96K, then the lightpipe input is useless for you. Either get a great SPDIF preamp like the API A2D, or record on another DAW platform and use a different interface entirely
Old 10-22-2010, 04:16 AM
paul_g's Avatar
Al, Thanks for the input. 48k should suffice, however, I am doing a project that is a bit involved. However I don't see using higher than 48k.
With that said, what about clocking? Is that handled through the light pipe or do I need to get the BNC cable to connect to the word clock of the 003?
Also, who becomes the master clock? 003 or the Digi Max?
Sorry for so many questions - Just trying to get the big and little picture.
paul_g
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
fruity loops in pro tools question...not regular rewire question nutrinoland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-23-2010 12:39 PM
quick question - Mbox Mini question - i forget JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2009 02:55 PM
Another optical expansion question question for boffins Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2008 11:21 PM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 02:41 PM
Chipset Question/Hard Drive Question andrewkstone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-26-2006 08:15 AM
