Old 09-26-2010, 06:26 PM
marcioguitar marcioguitar is offline
Default UA 1176LN connection
I just got a UA 1176LN compressor unit to use with my rig, this is my first compressor hardware unit since I have been using plugins for years. As far as connection goes what you guys recommend? Connect it as hardware insert or Mic > Pre amp > Comp > Converters? If I use the last option I won't have this compressor available for future mixing works, or is there a way to have it connected and take advantage in both situations?
Thanks for any suggestions
Old 09-26-2010, 11:47 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: UA 1176LN connection
A patchbay is the way to go! then you can use it pre converters when recording into pro tools and then patch it in to use it as an insert during mixdown. this is how i use my outboard comps.
you must use the inserts with matching inputs and outputs during mixdown to make use of the delay compensation.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-27-2010, 08:05 AM
Russ M. Russ M. is offline
You may have to load the output with a 600 ohm resistor for the meter and output level to be accurate unless you are interfacing with old style equipment that is designed around 600 ohms (I have some).
FS: UA 1176LN Mint Condition ejwells Buy & Sell 0 01-28-2013 02:05 PM
Connection Help 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-25-2007 05:58 AM
1176LN vs. 1176LN Vank Pro Tools TDM Systems (Mac) 5 11-24-2005 07:17 AM
Differences between the UA 1176LN and MC77 plug-in Imagine Pro Tools TDM Systems (Mac) 5 08-02-2004 10:24 PM
DAT Connection Help! popps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-15-2001 02:12 PM
