Masterlink and 002
I just purchased an alesis masterlink ml9600 and am thrilled with it! my question is should i use it to monitor out of? the d-a sounds really nice compared with the 002. while it sounds like i may have answered my own question, i'm really looking for others' experience with this combo and maybe some other ways of using it could be suggested. thanks. right now i have it connected by s/pdif but the unit also has analog outs. also, i did a mixdown last night feeding my tracks to the masterlink. i had to route every track to my spdf output in order to get it into the masterlink. why can't i just route the master fader to my spdf out? when i do, it shows no signal in the meters.... can you control-click and mirror the output on a masterfader?
MBPro C2D 2.2, 4gbRAM, external SATA. PowerMac G5 DP 2Ghz, 5 GB RAM, BLA modded Digi 002, 2 x 160GB Seagate SATA, PT 7.4, Mac OS 10.5 |
Re: Masterlink and 002
go to hard ware setup and click spidf mirroring and the master fader will go to the master link
also I own a masterlink but I dont like monitoring through it , because record enabled must be on and if you change sample rates you got to kick it back over to digital blah blah anyway In my opinion its a hassle but I do use the converters to track vox and stuff |
The 002 doesn't have the S/PDIF mirror option. Follow the directions in the 002 Getting Started Guide to send to multiple outputs.
Rail
u may have to change it in UTILITY from standalone mode
press PREF then SPDF then S/DIF again to toggle through RCA or Opt1 that should work and or in ur I/O setup |
If you open the Core Audio driver, and click on "Prefs", there's an option to "mirror analog outs 1 & 2 to digital outs". That might help.
664 The Neighbor of the Beast |
Masterlink with 002 | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-14-2006 05:15 AM |
Masterlink as A/D? | KaProducer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 07-11-2005 12:51 PM |
Masterlink ? | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-16-2004 02:46 PM |
DAT, CD, Masterlink, what to use? | Beegster | Tips & Tricks | 11 | 05-10-2001 11:55 AM |
MASTERLINK | LCM | Pro Tools TDM Systems (Mac) | 0 | 03-20-2000 12:33 AM |
