Import Session Data & Layouts
Hi.
I have our S6 set to save layouts to Pro Tools ~ blue star next to Pro Tools in the WS soft screens. Today I tried importing session data into a blank session from a session which contains layouts. I imported all tracks but the layouts didn't come in. Any ideas anyone?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: Import Session Data & Layouts
This is not implemented. How should this work though as you might not want your layouts overwritten if you import into a session that already has them. The best way is to save them in a title and then load them once you have the new session open. They should then import via the S6.
Hi Eddie.
Perhaps a layouts tab in the drop down where one selects which data one needs to import.
For the time being I would suggest at least importing them into the session in another slot as duplicates. This is how Windows configurations and markers work. A bit of a pain dealing with duplicates but you can delete them.
This suggestion is just meant as an interim release to get the functionality in there, while something more flexible is being implemented, like a prompt for where you want to assign the layouts or an option to omit a layout from import. Just ideas. |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Import Session Data with out Audio import | disinfor | Pro Tools M-Powered (Mac) | 7 | 11-14-2010 11:44 AM |
import session data without audio data | rgalpin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-06-2010 01:49 PM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
Import track color in import session data | deardaddy | Pro Tools TDM Systems (Mac) | 5 | 06-11-2007 06:35 PM |
