Clam Shell?
Hi All, Are there any known problems (eg over heating) when using a 17" Macbook Pro in Clamshell Mode...Cheers!
Re: Clam Shell?
There is no problem running in "Clamshell" mode since this is simply closing the display on the Macbook Pro. The cooling vents are located at the back below the display hinge and are not obstructed in the closed clamshell position. Make sure that you leave the rear of the Macbook Pro clear to allow proper ventilation (this is true for the display in both open and closed positions).
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Re: Clam Shell?
Thanks!!!
Re: Clam Shell?
I think you´d be better off keeping your MBP open when working in ProTools, since the keyboard area can heat up pretty drastically when working with big sessions.
iMac 3.1 GHz i7 Quad Core, OSX 10.8.5, 16GB RAM, PT 10.3.9 & PT11 MBP 2.66GHz Intel Core i7, OSX 10.6.8, 8GB RAM, Pro Tools 10.3.9 www.einarvilberg.com www.hljodverk.com |
Before I shell out 300$, I have a question | Violins77 | Pro Tools SE and Essential (Win) | 4 | 03-24-2011 02:41 AM |
VST Shell update | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-23-2006 10:15 AM |
VST Shell update | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-26-2005 09:30 AM |
Have to shell out another $100 to use VSTs? | joo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 03-24-2005 06:59 AM |
vst shell/wrapper? | mig 15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-23-2001 10:00 AM |
