Mbox2 and Triton Studio compatibility
I want to record sequences from my Triton Studio into PT. My Mbox2 only has 2 inputs, so I’ll need to make a couple of passes. Is there a way to slave the Triton to the Mbox2 and control the sequencer?
Thank you |
Re: Mbox2 and Triton Studio compatibility
Enable Pro Tools to send MIDI Time Code and the Triton to sync to it. You should also have their clocks sync'ed - typically by connecting an SPDIF cable from the Mbox 2 to the Triton and setting the Triton to clock to Pro Tools.
You can find information on synchronization in the Reference Guide, which is under the Help menu in Pro Tools. |
Thank you!
Still no luck.
I set the midi clock to external for the triton and i set up the triton in the midi studio set up in LE 7.3 and when I hit the start button in pt it doesn't trigger the sequencer. |
Do you have Pro Tools set to send MIDI Time Code or MIDI Beat Clock?
Problem resolved it's working fine now. THANKYOU!
Trigger Triton Studio Workstation with Pro Tools/MBox2 mini | Wize Dome | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-25-2007 08:14 AM |
triton usb compatibility | trinity1 | MIDI | 0 | 09-17-2005 03:15 AM |
Greetings! Triton Studio w/PTLE? | saintmaggot | MIDI | 4 | 03-19-2004 03:19 PM |
Help w/Triton Studio and PT6.1 | almous | Pro Tools TDM Systems (Mac) | 9 | 08-19-2003 12:00 PM |
Help w/Triton Studio & PT6.1 | almous | MIDI | 1 | 08-13-2003 12:35 AM |
