7.3.1cs3 Incorrect Peak Over Metering
Has anyone else noticed that it's possible to hit 0.0dbfs on a channel without lighting the red clip light with 7.3.1cs3? There is definitely something up with that, this has only happened since I've updated from 7.2 to 7.3.1cs3. Can anyone else verify this? Also I've been getting buggy ADC readings sometimes which has caused timing discrepancy's until I quit Pro Tools & re-open the session, it's a bit random & seems to be buggy with RTAS plugs in particular.
Matt |
Re: 7.3.1cs3 Incorrect Peak Over Metering
I'm on 7.3.1cs3 and my meters clip on 0.0dbfs I've got 10 tracks in he session that have all been mastered and are right on 0.0 they'r all clipping red. Are these tracks with or without plugins on? Chris
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 | hotgravy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2012 10:49 AM |
Peak Over Metering never light in 24bits record | ppm | Pro Tools M-Powered (Win) | 0 | 07-23-2009 11:33 PM |
Interesting metering software (with peak logging) | postprosound | Post - Surround - Video | 11 | 03-20-2007 02:36 AM |
Metering Average/Peak Levels | chateau | Tips & Tricks | 5 | 07-01-2003 12:35 AM |
Can someone explain the Difference between Peak and RMS metering | TriAxis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-27-2003 06:28 AM |
