Old 05-01-1999, 09:59 AM
Interval Interval is offline
Default Probs
Yesterday we have established PT24 and PT24 at start has informed:
"DAE Error - 4 was encountered"
DIGITEST has informed:
"ProTools device driver error. Error code 272. Shut down and try again"
we have a P2-350/128mB/9.1Gb HDD IBM SCSI2 UW 7200rpm/SCSI adapter Mylex (Bus Logic) UW/ Samsung 19" 900P monitor/SVGA Creative TNT 16 mB/
How to fix this problem?
Old 05-02-1999, 02:05 PM
Justin Justin is offline
Default Re: Probs
You'll prabably have to switch SCSI adapters. Use the Adaptec 2940UW, 3940UW or a mainboard with AIC-78xx (I use an ASUS mainboard with AIC 7890 - works fine) i believe PT can utilize the Adaptec driver only, and will refuse any other driver. I found the test features of the Install'o'rator utility to reveal several faults on my system. It's also far less cryptic than the Digitest (I used to get an "Error 4 - Failed". Really useful information for an end user).
Good luck!
Justin K.
SOS Studios
www.sos.as
Old 05-03-1999, 12:30 AM
Default Re: Probs
PT stops on a phase of loading DAE - why I should change the adapter ? DAE error 4 - is what?
Old 05-07-1999, 10:22 AM
Slypolk Slypolk is offline
Default Re: Probs
When I pruchased NT24Mix Digi recommended the adaptec 2940UW and 10,000 rpm drives.
It's possible the in not recommending other scsi cards they may have used some wisdom.
I would try the adpatec card before anything else.
I gad a 2940U wich was narrow but it wouldn't work ont hew wide faster drives so I purchased the recommeded card.
Hope everything works out.
Sly
Old 05-08-1999, 12:48 AM
Default Re: Probs
Oh, YES! I ran into xactly the same problem today. After completing a humongous mix yesterday without problems, today my afternoon started with a "DAE error #4 encountered". No new software installed, cords, cables and plugs untouched, no strike of lightning, no natural disasters. I rebooted several times - no use. I reinstalled the software - no use. I switched the machine off for 5 minutes and rebooted. Booyah! Now the little weasel acts as if nothing ever happened.
Although it's nice to be back on track, it's a little disturbing not to know when this'll happen again. What I need to know to troubleshoot this: Are the DAE-errors listed on the digiweb the same for Mac and PC? If not, could the PC DAE-error explanations please be made available? Thanks!
Justin K.
SOS Studios
www.sos.as
new probs yanncrusoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-29-2007 10:18 AM
2 different probs. Blue642 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-26-2005 05:13 PM
SP2 M-box probs... Eloquist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-25-2005 05:56 PM
DAE probs BBCalhoun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-03-2002 05:30 PM
Hui and PT5 probs Bill Padley Pro Tools TDM Systems (Mac) 8 12-22-1999 12:20 AM
