Old 08-18-2017, 06:56 AM
estokes1958's Avatar
estokes1958 estokes1958 is offline
Default "admin" vs "standard user" for 12.8
I am a PT instructor in process of upgrading my classroom workstations from PT 12.5 to PT 12.8. We are running Windows 7.
Everything works great on my "admin" (instructor) account. I am able to open sessions (for example the demo sessions included with 12.8).
However, the "standard user" (student) accounts cannot seem to access the audio output stream. Using asio4all with Behringer U-Phoria 2 channel audio interfaces on the student workstations.
This was never a problem with PT 12.5. Student accounts worked great.
Is there a new requirement to run PT 12.8 only in "admin" accounts? I would naturally rather not give my students admin access to the machines.
Thanks
Ed Stokes
UNC Charlotte
Old 08-18-2017, 11:54 AM
Default Re: "admin" vs "standard user" for 12.8
Wish I could give a better answer, but it has always been recommended to run it on the Admin account. Can you verify that the PT shortcut on the desktops have been set to "Run as Admin"
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 08-18-2017, 12:28 PM
Thanks for replying.
I always run my own sessions as admin. But as a teacher, it's not a good idea to give students admin privileges. And it was not previously required.
"Run as admin" option does not help, since the password needs to be entered every time. I would still need to give the students admin password.
Old 08-19-2017, 09:28 AM
The Weed's Avatar
The Weed The Weed is offline
Avid used to have a knowledgebase article about running PT in a non-admin environment, like schools or radio stations, where it wasn't desirable to supply users with admin privileges. Not sure if it still exists and/or if it's applicable to PT12. Perhaps it would be best to contact support.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Task Manager , "Obtain folder contents" , "Expanding Tree" ??? joachim Tips & Tricks 0 06-15-2015 11:10 AM
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] andrew24c macOS 4 07-23-2014 07:21 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
