Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 07-30-2023, 08:46 AM
Goombot Goombot is offline
Default Tightest video synch in ProTools without HDX
Is there some video option besides using Synch X and HDX that is a tighter video synch than the native video engine?
Old 07-30-2023, 09:03 AM
its2loud its2loud is offline
Default Re: Tightest video synch in ProTools without HDX
This is one option
https://non-lethal-applications.com/...5/video-sync-5
Not sure it provides frame edge sync without HDX and Sync X but it does take the load off of Pro Tools and can run on the same system.
You can run a leaner Pro Tools session and turn off the Avid Video Engine and have Video-Sync 5 handle the video portion. I believe it uses the built in Pro Tools Satellite feature to sync up to PT.
Old 07-30-2023, 09:51 AM
BScout BScout is offline
Video Sync uses Avid Satellite to link. However, Avid's Video Engine process does the same. So if one is a tighter sync than the other is going to simply depend on the video engine and how well it is written for the codec in question.
However, as others have measured, using video hardware (like the mini video outputs from Blackmagic) improves the sync. Or, more accurately, makes the video delay more consistent so it can be offset in the Pro Tools setting. With a consistent offset, you can get it near frame accurate every time.
2 other things:
Interframe compression codecs (h264, h265) are less accurate than intraframe compression codecs (ProRes, DNxHD/DNxHR). So convert video to an intraframe code if you want tighter accuracy.
The only way to get guaranteed frame edge accuracy is with the SyncX or SyncHD using genlock and tri-level sync (will need a generator with the SyncHD) and then an output card that uses genlock and then, hopefully, a display/projector that uses genlock.
Old 07-31-2023, 01:16 AM
Depends on what you consider "tighter". Technically speaking the *only* way to achieve frame edge lock is with AVID hardware (HDn/HDx cards plus SYNC HD or X) and a genlockable video hardware (which includes non-lethal plus a card with genlock input). Everything else will only get you close. The AVID video engine will then lock to the common ref.
Old 08-01-2023, 11:26 AM
Ok thanks for all the info. It's really silly that Avid is creating a new product (Synch X) that relies on a decade old technology.
Internal Video Synch vs Synch X with Native Cards Goombot Post - Surround - Video 2 07-16-2023 10:39 PM
Video Synch Offset for 25 fps JimLeb Post - Surround - Video 4 11-14-2008 11:42 AM
synch Pro Tools LE with video from DV camera?? doozerco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-21-2004 02:50 PM
New to audio-video synch popps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-02-2002 12:27 AM
SYNCH TO VIDEO QT? ALBERTO B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-31-2000 09:39 PM
