Old 06-12-2010, 02:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default opening leopard session in Snow Leopard, quit on opening!
Got an entire album recorded and mixed in Leopard, and all's been working well. (except occasional SSL Duende quits)
I decided to go to Snow Leopard after holding off for 6 months due to some plugs not being compatible (Serato etc) spend a whole day checking and updating all plugins etc.
Now when i load any of the big finished session mixed in leopard they quit on opening!! So i tried opening the session holding shift to disable all plugins. the session opens fine! so i re-activate all plugins one at a time to try and find the culprit and they all activate ok and the session runs ok. usually if a plug was causing problems this would identify the culprit as soon as it was activated!!
I haven't had time to investigate further as i booked up for a while, and each quit involves a re-boot 15 minutes etc. but this seems a bit strange.
It probably is a plugin and i'll try and go thought the obvious process to eliminate. but if anyone wants to take a look...
crash log...
http://www.sendspace.com/pro/dl/jnvwtd
several dlogs...
http://www.sendspace.com/pro/dl/6eg4a4
Chris
Producer, Engineer,
www.ukmastering.com
Leopard to snow leopard clean or update install joji Pro Tools TDM Systems (Mac) 10 01-01-2011 02:21 PM
Couldn't get snow leopard install to stabilize from leopard clone update! crizdee Pro Tools TDM Systems (Mac) 2 01-11-2010 04:45 PM
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard DigiTechSupt Virtual Instruments 0 01-07-2010 11:08 AM
If buying Imac and MBox2 tomorrow: Leopard or Snow Leopard? Jairo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-22-2009 03:13 PM
PT 7.4.2 + Leopard 10.5.4 SUPER SLOW OPENING SESSION Paul B. Pro Tools TDM Systems (Mac) 5 08-01-2008 11:58 AM
