Old 12-16-2009, 02:16 PM
thekrynn thekrynn is offline
Default Original MacPro - Which PCI Slot
Hello.. I'm adding an Accel HD1 system to an original MacPro of mine -- Dual 2.66. The machine's setup to do 8/8/4/4 for the lane speeds (as I'm using the graphics card in lane 1 and have 2 other cards - a fibre channel board and a video editing board).
The fibre channel only requires 4x but the video can work in either 4 or 8. Question is... does it matter and is it a performance difference between putting the HD in either the 4x or the 8x slot?
Old 12-17-2009, 06:05 AM
drenkrom drenkrom is offline
Default Re: Original MacPro - Which PCI Slot
The PCIe PT cards are 1x so any additional lanes won't even be contacting the card. You don't specify what "video editing board" model you have, but I'd be inclined to give that the remaining 8x lane, as bandwidth is sure to be much more of an issue with that than with the Core card.
As any time you combine differing PCI cards in a computer, you may have to swap them around while troubleshooting if things go way wrong, but I haven't had to do this personally on a MacPro up to now and I've set up a few funky systems.
IHTH
Using carbon copy to move from macpro to a newer Macpro fourthtunz Pro Tools TDM Systems (Mac) 2 04-10-2012 02:39 PM
Slot placement on MacPro Rikk Pro Tools TDM Systems (Mac) 3 02-17-2011 07:31 PM
Slot placement in MacPro Westmere Rikk Pro Tools 9 0 11-18-2010 06:27 PM
Magma 4 Slot 8 Core MacPro studiom Pro Tools TDM Systems (Mac) 11 04-30-2009 04:38 PM
Card Slot Order MacPro Dual 3.0 Quad Touchwood Studios Pro Tools TDM Systems (Mac) 7 05-29-2007 06:18 AM
