Old 08-17-2011, 03:01 PM
james21789 james21789 is offline
Default i7 Build - BSOD
Hey everybody,
I've been trying to get this i7 build up and running for WAY too long. For some reason it seems I'm running into every possible problem. I even paid someone to make sure all the drivers were installed and the system was running properly. The machine runs slow for how fast it should be. For example, when I open PT it takes a couple of seconds to even open up the PT loading window. Before PT can open, I get a hard blue screen force restart. The error message is "BAD_POOL_HEADER" 0x00000019. I'm running PT8. I believe this has something to do with RAM but I really have no clue beyond that. Any help would be greatly appreciated.
Thanks,
James
Here's the sandra:
SiSoftware Sandra
Computer
Model : GigaByte X58A-UD3R
Workgroup : WORKGROUP
Host Name : PTRIG-PC
User : PT RIG
Processor
Model : Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Speed : 3.1GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Mainboard : GigaByte X58A-UD3R
BIOS : Award (OEM) FB 08/24/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 6GB DIMM DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 2.43GHz (4.86GHz)
Chipset
Model : Giga-Byte Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 400MHz
Memory Module(s)
Memory Module : OCZ OCZ3BST2000C8LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4)
Video System
Video Adapter : ATI Radeon HD 5450 (80 SM5.0 650MHz, 512MB DDR3 800MHz 64-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : ATI Radeon HD 5450 (80SP 2C 650MHz, 512MB DDR3 800MHz 64-bit)
Compute Shader Processor : ATI Radeon HD 5450 (80SP 650MHz, 512MB DDR3 800MHz 64-bit)
STREAM GP Processor : ATI Radeon HD 5450 (1SP 2C 650MHz, 512MB DDR3 800MHz 64-bit)
Storage Devices
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (E:)
HP DVD Writer 1270r (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Sessions (E:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
Optical Drive (D:) : N/A @ HP DVD Writer 1270r (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Audio Device : PC Partner Manhattan HDMI Audio [Mobility Radeon HD 5000 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : Giga-Byte 4 port SATA IDE Controller
Disk Controller : Giga-Byte 2 port SATA IDE Controller
Disk Controller : Giga-Byte 88SE91A3 SATA-600 Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 3.8
Old 08-17-2011, 05:11 PM
Default Re: i7 Build - BSOD
Storage Devices
Check the BIOS M.I.T that the Memory Frequency is 1066, although I'd seat DDR3 1333. Is Marvell 9128 Driver installed for those SATA3 6GB HDD's? Are they connected to GSATA Bus 6 and 7?
Aaron Mulqueen - 001 HD Native
Old 08-17-2011, 09:57 PM
zedhed's Avatar
zedhed zedhed is offline
Whilst this is probably not the cause for BSOD it should help PT performance once you are up & running.
Download and install the plugin updater file from here;
http://avid.custkb.com/avid/app/self...p?DocId=362895
Click on view Available Downloads.
In Pro Tools go to Setup>Playback Engine and set processors to one less than you have currently set & select CPU limit to 95%. If necessary keep decreasing processors x1 increment at a time checking after each change. Set Cache level to 2.
If you have any incompatible plugins your performance will go down. The plugin updater file should take care of most but you may want to check plugin compatibility list;
http://avid.custkb.com/avid/app/self...p?DocId=343311
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 08-18-2011, 12:55 AM
mano111 mano111 is offline
BSOD is, more often than even I'd like to admit, a hardware issue. RAM is most common cause, then it could also be the motherboard CPU or display adapter.
I cant tell you how many cases of BSOD I've solved just by replacing the RAM with a different brand. (see the motherboard support list in the gigabyte website)
When looking at your specs and Sandra report, it seems like your RAM model is CL8 yet its running in CL7 timing. 1st thing would be to loosen the timing and make sure all RAM speed and specs are setup to manual (not AUTO) and using correct values in the BIOS.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 08-18-2011, 01:03 PM
I originally suspected the RAM as a faulty component, but I have replaced it twice already. This ram is supported by my mobo as well. When I paid a technian to work on the computer, he did extensive testing on the RAM and CPU through sandra and everything tested really well. I am fairly certain this is not a hardware issue.
I'm using the OCZ spec timings for the sticks. Memory Frequency appears 1349.71 MHz in M.I.T.
I'm guessing the 6GB was a typo and you meant 1TB.
I installed the latest chipset drivers from gigabyte. They are not Marvell 9128 drivers. Why do you believe I should be running this driver?
They are plugged into SATA2_0 and SATA2_1. Is this a problem?
Thanks for the responses, I really appreciate it.
Old 08-18-2011, 03:42 PM
Should that Memory Frequency display roughly 1333 MHz in M.I.T?
I'm guessing the 6GB was a typo and you meant 1TB. I installed the latest chipset drivers from gigabyte. They are not Marvell 9128 drivers. Why do you believe I should be running this driver? They are plugged into SATA2_0 and SATA2_1. Is this a problem?
No, not really a problem but more beneficial if you use those 1TB SATA3 (6GB Transfer speeds) on GSATA (Gigabyte SATA3 Chip driven by Marvell 91xx?
Old 08-20-2011, 01:58 AM
MikeLip MikeLip is offline
You tried running on just one stick of RAM?
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 08-20-2011, 03:42 AM
yes, I don't think RAM is the culprit.
I tested the HDD's in Sandra and they came up with mid ranged overall scores (5-6). Does the seem low for the drives?
Old 08-20-2011, 07:06 AM
Which version of PT8?
Mike.
Google the DUC
Search Avid
Old 08-20-2011, 04:13 PM
Pt 8.0 le
BSoD with my new i7 build...not sure what to check next Mathgamain Windows 6 09-07-2012 09:14 PM
New Build Review! Based on Mano/Ame? and SPCR Fanless build Calipoop Windows 4 11-16-2011 09:38 PM
To build or not to build? Money is the question... storm-01 Tips & Tricks 5 09-23-2003 01:08 PM
To build or not to build? Money is the question... storm-01 Pro Tools TDM Systems (Mac) 12 09-19-2003 07:40 PM
To build or not to build? Money is the question... storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-18-2003 09:13 PM
