Urgent help - audient asp008 aes and digi 192
Can anyone help -just bought an Audient ASP008 and cannot get a digital signal out of the unit via aes into the Digi192....
I am getting a signal in on every channel but not a thing out digitally - the word clock is set to external on the ASP008 and the digi I ve set dig input to aes... I ve gone into pro tools and set input in session on 8 tracks to A9 - A16 BUT NOT A THING comes in- any ideas? - Hope someone can help Thanks Karl |
Re: Urgent help - audient asp008 aes and digi 192
A lot of things are left vague in your post. I’ll try my best. On the back of the ASP008, did you select “AES” as its digital output format? (For AES, the push button must be in the “Out” position.) Quote:
In Hardware Setup - [Digital] tab 1) Select AES/EBU as the Input Format In Hardware Setup - [Main] Tab 2) Select ascending “AES/EBU” pairs (i.e. “1-2” through “7-8”) for each pop up menu listed in the “Input” column, starting with the pop up labelled “9-10” (because it seems that you are using 1-8 for your analog signals). IO Setup - [Inputs] tab a) Create four stereo inputs. c) Name the above “ASP 1-2”, “ASP 3-4”, etc. c) For each of the above, create a pair of sub-paths (mono). Incidentally, ProTools will append “.L” and “.R” extensions to these. I like to go in and edit the names of these mono paths with the appropriate channel name and number. For example, I’d rename the “ASP 1-2 .x” sub-paths as “ASP 1” and “ASP 2”, respectively. d) Be sure to assign the proper “Pez” buttons on the grid, for all the above. In your session, you should now be able to select “ASP X-X” as your inputs, and receive signals. If things still don’t work, I’d investigate the cabling (also left unclear in the post) used to make the digital connection between the ASP-008 and the 192 I/O. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
If you're ruled out the obvious, the likeliest cause does seem to be the snake.
There are two different popular standards for running four stereo channels of AES/EBU through a DB25 connector. Are you sure you have the right one for the 192? JSL |
Digidesign 96io clock + Apogee MINIME + audient ASP008 | YellowDissident | Digidesign Hardware & Software | 0 | 07-18-2013 07:55 AM |
Help - audient asp008 aes output into 192 | karljohnson | Pro Tools TDM Systems (Mac) | 0 | 05-07-2010 03:19 PM |
digi please! I need an urgent advice | Mubeau | Pro Tools TDM Systems (Mac) | 0 | 12-20-2005 11:16 AM |
DIGI Urgent | Xplosvebob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-03-2002 06:12 PM |
pro control vs audient | speedyk5 | Pro Tools TDM Systems (Mac) | 0 | 01-23-2002 04:21 PM |
