Old 04-30-2021, 06:48 AM
marsian marsian is offline
Default S1/DOCK/Control loose connection every now and then...
Dear users,
maybe someone got a hint for me.
I'm using 2xS1 a DOCK and Control with the newest software. Once a day (and sometimes more often) the units loose connection with the EUCON software for about 20 seconds. Then they are back again.
EUCON is on a separate network (second LAN on my MP5,1) with a extra router and small network switch. The router is DHCP server.
I tried different DHCP settings and different IP ranges, but it didn't help.
Best
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 05-01-2021, 10:12 AM
EddieJones's Avatar
Default Re: S1/DOCK/Control loose connection every now and then...
You need to find out what loses connection. If the tablet does, it will look like everything did as they all reconfigure with the new number of surfaces.
Old 05-03-2021, 01:58 AM
Thank you Eddie.
I will try out, if it's the iPad, that is the cause.
Best
Maik
mars13.de
Old 05-06-2021, 05:52 AM
...ok I identified the control app on iPad as cause.
It doesn't matter if connected via LAN or WIFI, DHCP or fixed IP.
Without the iPad, the S1s and DOCK are stable.
Could it be the update to iOS 14.5? I think, that it got that worse since I updated.
Best
Maik
mars13.de
Old 05-06-2021, 09:00 AM
EddieJones's Avatar
Do you see the Control App crash? is there some other program popping over it that causes it to lose focus ?
Old 05-06-2021, 09:05 AM
Hi Eddie,
no, no other app running. No notifications going on.
Best
Maik
mars13.de
Old 05-06-2021, 09:08 AM
EddieJones's Avatar
So the App stays running but just disconnects (and you see the red exclamation in the top left of its screen?) I'm on 14.5, just updating to .1 now
Old 05-07-2021, 03:27 AM
...exactly, there's a red exclamation in the app.
mars13.de
Old 05-07-2021, 09:38 AM
EddieJones's Avatar
Can you check the recommended settings on this page and make sure the router is setup correctly. Control App help
Old 05-10-2021, 05:06 AM
Thank you Eddie.
I found on my small tp-link switch, that IGMP snooping and QoS was active.
Changed it and will observe, if it get's better.
Best
Maik
mars13.de
Recommended ethernet switch for Artist and Dock Connection sjgam Artist Series 5 10-19-2018 09:09 AM
Control App with Dock Connection Question sjgam Avid S1, S3, Dock and Control App 1 10-19-2018 08:12 AM
Some Faders or Buttons Randomly Loose Connection Barry Johns ProControl, Control|24, Command|8 1 06-14-2014 01:40 PM
MBOX 2 USB connection Loose! help mfaktr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2008 12:04 PM
Orig MBox Loose USB Connection. Any Suggestions? Matt Foglia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-22-2007 12:00 PM
