Old 03-09-2002, 06:41 PM
Cor Despota Cor Despota is offline
Default Newbie can\'t get system running. HELP!
I just purchased what I thought would be an awesome computer to power ProTools, and now I'm not so sure. I am having all sorts of problem running PT and I don't know where I can begin to fix them.
The system I bought has:
Pentium 4, 1.5GB processor
512 MB RAM
40GB HD, plenty fast
SB Live! 5.1 soundcard
Win 98
The probems I'm experiencing:
1. When I play back audio tracks they crackle big time, though the level meters are reading fine. This comes and goes, but once is starts it keeps happening.
2. Skipping to accompany the lovely crackling.
3. The scrolling play bar lags behind the audio being played.
If anyone can shine some light on any of this I would be extremely grateful. My dentist would also appreciated it, as I have spend the last couple hours grinding my teeth in frustration.
Thank you,
Cor
Old 03-10-2002, 12:52 AM
geetarbill geetarbill is offline
Default Re: Newbie can\'t get system running. HELP!
In PT, select setups and hardware, set the sample rate to 48000. The 44100 sample rate won't work with SBLive sound cards since they sample at 48000. It will change your timing and pitch on the tracks. To get around that, start a new session and import the old tracks into it. It should convert the sample rate without changing the tempo and pitch. I hope this helps.
geetarbill
Old 03-10-2002, 10:36 AM
Stone Knife Stone Knife is offline
Another thing- PT Free requires a lot of buffer samples (even on a machine that'd run LE on just 128)I had to run about 1,000 to 2,000 buffer samples (forgot what the exact #'s are).
When you're on the edge of buffer underrun you'll sometimes get the sound breakup.
If you get the sample rates straightened out and it's still happening, please repost or e-mail...
Got a good laugh at the 'Lovely Crackling". You've gotta be in radio.
Good luck...
Old 03-12-2002, 11:03 AM
Well, the sample rate seemed to be the cause of my problem. I changed it to 48 and the skipping is virtually gone.
I've got a bigger problem now, I can't record, but I think I'll post it as a separate topic.
Thanks for the help.
-cor
HTML code is On
Newbie questions regarding sotware running PT 10 ZedLeppelin macOS 3 01-05-2013 10:46 AM
Newbie help with system lock ups frodebass Windows 3 10-10-2012 06:21 PM
so i just got my new mac PT system up and running idleave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2009 04:51 PM
Running v8 and 7.4 on the same system? cKaz Pro Tools TDM Systems (Mac) 2 04-10-2009 11:12 AM
how to tell if your system is running right? xodiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-12-2008 08:24 PM
