Melodyne killed my computer Help!
I finally got my 003 yesterday. Hooray! Came with 7.3.but it was easy to down load and activate /authourize the 7.4.2 upgrade.
I then proceeded to load all the add ons that came with the ignition pack. All loaded fine EXCEPT the melodyne plug which failed to load with a message saying that is was missing some components. No Biggie says I---Wrong! Now Protools will not launch. In the window that opens while it is loading up it hangs on D-Verb.dpm. In finder I went and found all instances of ‘‘melodyne” and dragged them to the trash. Repaired permissions and ran the little utility program to delete all pref/plist/etc. Still no joy. Worse than that, Cubase 4 which I also own will not launch anymore either. When it gets to melodyne essential it aborts!! ARGGH! When I search in spotlight I can find no melodyne components. My local L+M guy where I bought the unit says I must still have a corrupted codec somewhere that is corrupted and causing things to hang. BTW I did a ptle only install on an external lacie firewire drive and PTLE works fine. Any assistance greatly appreciated. Step by step preferred. I’m not a total newbie but I can still get myself into trouble. MacPro 8 core 10.4,PTLE 7.4.2/003R RME fireface800/Cubase 4 TIA Brian |
Re: Melodyne killed my computer Help!
Just to clarify. After I loaded basic PTLE 7.4.2 I imported an old session and it worked just fine
Update all of your plug-ins for Leopard compatibility:
www.digidesign.com/leoplugs Especially Melodyne and the rest of the Ignition Pack 2 software: www.digidesign.com/ip2help
Administrator Avid Pro Audio Community |
[quote=Digidesign;1288704]Update all of your plug-ins for Leopard compatibility:
www.digidesign.com/leoplugs Especially Melodyne and the rest of the Ignition Pack 2 software: www.digidesign.com/ip2help[/quote Of course that makes sense now! Is there a quick way to remove all the plugs and their associated files and then start from scratch? I'm assuming the digi rack plugs I downloaded with the 7.4.2 are leo happy? Thanks |
Go to Mac HD / Library / Application Support / Propellerhead Software / REwire and trash the 2 files that say Melodyne.
Go to your apps folder and trash the Melodyne folder. Now if you want, go to Celemony.com and log-in and register Melodyne Uno and donwload 1.8.1 or higher to be leopard supported. It should recommend 1.8.3 or whatever the latest is automatically to you.
regardless, this is exactly what you need to do (oh premo, i wish i knew of this post on friday) |
Premo you are indeed Primo!!!!!
I never would have found those two files in a million years. Thank you! Thank you! Thank you! This should be in a faq somehere! The DUC Rocks!!!!!!!!!!!!! B Quote:
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Mac) | 2 | 09-18-2009 06:31 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Win) | 2 | 09-18-2009 12:15 AM |
Melodyne Studio 3.2 Bridge not communicating with Melodyne -- help! | nuggitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2009 03:02 PM |
Help! 6.1.2 update killed my computer! | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-14-2003 11:16 PM |
AverTV Stereo has killed my computer! | 8mmOverdose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-18-2003 12:00 AM |
