Re: Shan, Guitardom, Quad Gurus, God...anyone?
wont it run 2x's as fast that way?????
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Yeah these are definitely too high suggesting a hardware issue. If these are idle temp it is way too high as a slight load would push it to throttling and either freeze the system or restart. Could be CPU heat sink, an unplugged fan maybe. BIOS settings could also affect this if CPU or RAM voltages are set too high. Quote:
this "trick" of running 2 instances of PT is not gonna cut it IMHO. You need to be able to run it by the book or you will just be having more and more issues. What version of windows are you using? What tweaks have you done to the system / BIOS ? What PT interface are you using? Why is your report so different than what I am used to seeing? I have many questions but to be honest I am not an AMD (or TYAN) user and could not provide any strait answers
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
@guitardom
-running Microsoft Windows XP Pro Version 2002 SP3 -DEP is off in add or remove programs theres only one Microsoft Visual C++ 2005 Redistributable 8.0.56336 -Video drivers updated and correct -Had it built around 18 months ago by pcaudiolabs -Fresh OS install last night hope this helps stop the problem @mykhal I figured out the double instance thing by accident. Pro Tools hung during startup and I just clicked on the exe again, and it woke up and finished loading. So I just do it because that way Pro Tools end up actually starting every once in a while. thanks! |
@Mano
I appreciate all the help I can get. Im using Windows XP Pro Version 2002 SP3, and an Original Mbox, I havnt tweaked the BIOS except for disabling onboard audio and following Shans BIOS setting from the quadzilla thread, the machine was built by pcaudiolabs so any other tweaks came from them. I didnt realize my report was so different but Im not exactly experinced with Sandra, if you want to see any other report Id be more than happy to post it. thanks again |
#16
You might be onto something there! |
#17
also list any bios changes. the opterons are not friendly to lots of tweaking and overclocking.
#18
Is there any way to get a .txt on BIOS settings so you guys can see the whole thing?
Once agan I didnt build it (and even if I did id have no clue about BIOS settings). |
#19
make sure that you have the latest PACE drivers tho. we really have no idea of what calls are bein' made in PTLE specially on load. just sayin'...
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#20
Hand picked fresh drivers from Paces backyard installed as wel.
Shan!! Need help_Reaper | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 33 | 12-22-2015 06:36 PM |
hey shan | stixstreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-30-2009 06:17 AM |
Hey Shan and other Quad Experts | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 03-24-2009 04:15 PM |
QUAD - CPU Spikes - SHAN....... | IntelDoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 11-19-2006 07:58 PM |
Hey Shan? | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-28-2005 07:20 PM |
