Old 05-17-2022, 11:19 AM
dr sound's Avatar
dr sound dr sound is offline
Default Re: Altiverb XL + Stereo/Quadro IRs - Good for LCR?
Originally Posted by rantanplan View Post
Thanks, I know the plugin. But I wonder what it really does when you "tie it to the center"...
Why don't you get a demo and try it?
We can discuss "does it...?" all day long.
Instead try it and see.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 05-17-2022, 11:52 AM
BScout BScout is offline
It's a panner & level at the end of the day. It does what you tell it to do. In the case above, bleed some of left and right reverb into the center.
Old 05-17-2022, 12:05 PM
Cheesehead Cheesehead is offline
That's reassuring! You also did stereo downmixes?
Yes, many feature film stereo downmixes, no problems at all.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 05-17-2022, 12:15 PM
rantanplan rantanplan is offline
I don't necessarily want an additional plugin, if I can do the same with PT's own panner.
Old 05-17-2022, 12:16 PM
Perfect, thanks!
  #16
Old 05-17-2022, 03:01 PM
spoons's Avatar
spoons spoons is offline
You can’t, which is why we are suggesting it.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
  #17
Old 05-17-2022, 04:59 PM
Isn't the divergence adjustment on my Pro Tools surround panner doing this? Bleeding into center speaker.
  #18
Old 05-17-2022, 06:53 PM
gives's Avatar
gives gives is online now
I use Spanner after Altiverb to toe it into the centre when using it on dialogue.
Spanner is my go to also. Use it in Atmos at well to deal with overlaps of object etc.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
  #19
Old 05-17-2022, 07:33 PM
You have zero control of the levels on L, C, R with the divergence control. If you bleed to C, you are losing L and R. Then you have to compensate levels with another plugins to push L/R. And down the rabbit hole you go.
Along this same path you could create a send to sub-channel C. But once again, a pain.
Spanner is a great utility plugin (not to mention some of the rotational possibilities with the accompanying tablet app) but there are many ways to skin this cat. (Sorry cats!)
  #20
Old 05-18-2022, 02:19 AM
Farhoof's Avatar
Farhoof Farhoof is offline
In Protools you can only pan mono or stereo tracks outputting to quad or 5.1 (or something bigger than mono/stereo).
In Protools you can not re-pan a 5.1 into 5.1 (like re-pan the surrounds a bit more towards the fronts). Spanner allows you to do stuff like this.
Also beware, Altiverb has buggy automation when using the 'center level'. It needs to pass an automation breakpoint in order to get the correct setting. When you reopen the session the level is at default (if I remember correctly) and only jump to the correct setting when it passes a breakpoint.
This might be fixed by now though, I hardly use Altiverb, but it was there for while.
HTML code is On
Quadro NVS 295 Video Card - x1 or x16 David Lang Windows 0 03-06-2012 02:17 AM
NVidia Quadro required? being_me Pro Tools 10 7 12-28-2011 12:59 PM
Altiverb 7-XL rtas in PT 9-TDM - OS 10.6.x - good or bad? MixerGuy Pro Tools TDM Systems (Mac) 6 12-12-2011 10:14 PM
GeForce vs Quadro vs ? dstryrwiz Pro Tools 9 4 02-08-2011 09:02 PM
good stereo pre for oh.... nate9 Pro Tools TDM Systems (Mac) 9 05-11-2009 12:54 PM
