Old 05-05-2017, 03:08 AM
Sergey_111 Sergey_111 is offline
Default Crackling in Pro Tools 12
Hello! While working with Pro Tools 12, some kind of crackling occurs. Why this can be and what needs to be configured in the program? Did someone happen this? I use Windows 10 Pro and a sound card focusrite scarlett 18i20 (1st generation).
Old 05-05-2017, 04:52 AM
Default Re: Cracking in Prp Tools 12
Nobody faced with this? Noise or clicks in the program?
Old 05-05-2017, 05:21 AM
Southsidemusic's Avatar
We use Mac only here but what is your computer specs?
Please post a free Sandra report with hard drives and peripherals plugged in and we can see about your system.
Also what buffer size do you have set?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-05-2017, 05:48 AM
Windows 10 pro, 8 GB of RAM, intel core i5-3470 cpu @ 3.20 GHz
audioman1973 audioman1973 is offline
First thing to try is set your playback buffer higher in Settings >Playback Engine. You could also try increasing Disk Cache. If those two things don't help there may be other issues and if that's the case trashing prefs and posting the Sandra Report may help pinpoint the problem as these other fine folks have suggested.
Pro Tools Ultimate 2023.9. Mac Studio M2 128GB Ram 24 Cores 4 TB HDD. 2 Universal Audio Satellites. Lynx Aurora N.
Old 05-05-2017, 07:23 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi Sergey ! There are a few things that can cause this .
What hard drives and how are you recording ? ( Is important what chris ask you , more detalied system report would be helpfull )
Make shure to have all your drivers upated specially the chipset drivers .
And last make shure to have all the windows optimizations done .
http://avid.force.com/pkb/articles/e...ndows-10-Guide
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 05-05-2017, 10:21 AM
Thank you! I will try to do all this. I just used FL Studio earlier and did not notice any performance problems.
Old 05-06-2017, 02:17 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by Sergey_111 View Post
Hello! While working with Pro Tools 12, some kind of cracking occurs. Why this can be and what needs to be configured in the program? Did someone happen this? I use Windows 10 Pro and a sound card focusrite scarlett 18i20 (1st generation).
As usual, the advice here is top-notch. Assuming you've checked all of the above, here's something else. Sometimes The whole audio suddenly sounds garbled and distorted, and just changing the buffer setting to something else (either lower or higher) in the playback engine resolves this. I usually work at 512, and moving to 256 and back again always solves it. It's a strange bug that I never noticed before v12, but that may be because I jumped from v8 to 12.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 05-06-2017, 02:58 AM
Lesbrunn, thanks! I am very grateful for the advice!
Old 05-06-2017, 03:12 AM
lesbrunn's Avatar
You're welcome, bro. Hope you find a solution soon.
Crackling and Static on Pro Tools 11 jzaid22 Windows 6 07-30-2015 08:17 AM
Crackling & Hissing in Pro tools 9.0.6 [email protected] Pro Tools 9 1 04-14-2012 10:33 AM
Pro Tools 8 crackling quadrifoglio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2011 09:22 AM
Still getting crackling sound with Pro Tools 9 Ransom Pro Tools 9 21 01-10-2011 12:36 PM
pro tools crackling problem n8tron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-10-2010 02:10 AM
