11R and Tech 21 power engine
Is there anyone here who uses an 11R live running thru a Tech 21 power engine? If so, how are the results and if you can give me a run down of how you have it set up.
Re: 11R and Tech 21 power engine
Yep!
I have it in my studio and I use it to hear the differences in the actual recorded tones. I also have the Tech 21 Power Engine 60T (discontinued acoustic model) and I run them both at the same time. I have used both the stereo outputs and the Amp out, and I do not favor one or the other. YUP!
I Am Jamsire |
So how is the sound. Does it capture the true sound of the 11R or does it color it?
I would like to know this too. Still searching for a good solution for playing live and at home (my studio monitors are crap ).
I use a power engine with mine. While it may not be 100% flat, sounds I dial in on it seem to translate well to our church pa system.
I had a Power Engine that I used to use with my Pod. Pretty cool actually. Will it be the same as what you're sending to FOH? Probably not, but is does allow some EQ compensation, so you can get close.
Tech 21 Power Engine 60: Ultimate 11R Cabinet? | Fezzler | Eleven Rack | 7 | 01-03-2012 07:05 AM |
Equi=Tech power systems - anybody using | WildHoney | Pro Tools TDM Systems (Mac) | 24 | 04-19-2006 02:39 PM |
Any tech heads find a way to power 001card on G5? | KingFish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-25-2004 11:34 AM |
Power Engine 60 | Notefarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-02-2003 11:26 PM |
Power Tower Pro 225 / Newer Tech G3 Question | tld | Tips & Tricks | 1 | 12-16-1999 03:51 PM |
