Revibe AAX Reverb One AAX
I´m facing big problems with sessions mixed on protools HD 8.1.1 (or 7.4 or 9.x.x) regaring automation with TDM Reverb One:
When I open these sessions in Protools HD Native 10.0.1 I first have to switch the Reverb Ones from "TDM" to the new version of Reverb One AAX. Which is ok. BUT all values I automated in my session are completely different in the new AAX version! (room hall small became large etc...) Since reverb one still is one of may main reverbs for TV Postproduction this is horrible. I tried copying values, make new tracks for Auxes, etcetcetc everything that helped with automation bugs sofar (im on protools since PT 4.1).... I guess the automation transfer between TDM and AAX simply doesnt work properly in the actual version of Protools HD. Ideas? |
Re: Revibe AAX Reverb One AAX
In my testing of Reverb One automation created in Pro Tools 9 TDM everything played back correctly in 10.2 aax version. It was my understanding that 10.2 should be used with the new aax Reverb One. That said, Reverb one automation created in Pro Tools 10.2 aax version will not play back for me at all in Pro Tools 9 TDM. The plug-in is deactivated and as a work around I re-automated the session with the same settings (from memory) on new aux tracks with the old TDM version. It seems to be forward compatible but not backward and does not give me the option to go between TDM and aax as you could with RTAS versions.
What if you open Reverb 1 as a native plug?
REVIBE and REVERB ONE | misioka | Buy & Sell | 5 | 07-25-2013 02:30 PM |
Will Revibe II, Reverb one II Run on AAX? | ThomasPMusic | macOS | 1 | 12-06-2011 05:01 AM |
Revibe and reverb one | FilterDecay | Pro Tools HDX & HD Native Systems (Mac) | 5 | 06-13-2011 01:48 PM |
Revibe vs Reverb One | brianjanthony | Pro Tools TDM Systems (Mac) | 13 | 11-24-2005 04:04 AM |
Revibe or Reverb One | Cliffy_Boy | Pro Tools TDM Systems (Mac) | 12 | 06-06-2005 08:16 AM |
