Old 09-04-2021, 10:42 AM
Default Re: Colour Palette
Originally Posted by musicman691 View Post
You're definitely OCD - I thought you were kidding about that. If this little bit upsets you then I don't know what to say.
Actually it's OCPD, which in the normal world is a pain in the arse but for engineering has actually proven quite an asset. But as Marsdy correctly points out, you don't need to have OCPD to just want tidy session window(s).
Old 09-04-2021, 02:16 PM
Originally Posted by Marsdy View Post
Don’t say anything if you don’t understand what’s happening. You clearly don’t.
It’s nothing to do with OCD. Many of us leave the the Colour Palette open in the obvious place over the toolbar where there’s space for it. It now obscures the bar number and marker lanes of the Edit Window. It’s poor design which requires opening and closing the Colour Palette to see the bar numbers and markers. Previously it didn’t.
Midnightrambler is the one who brought up the subject of OCD.
Old 09-05-2021, 02:51 AM
You still seem to be here, commenting on something you don’t care about *shrug*
Old 09-05-2021, 03:39 AM
I'm just pointing out that it's not a simple 5 minute couple of lines of code fix either. If the text isn't there people won't know what the arrow is for unless they read the manual and you know a lot of people don't. Combine that with it being something most people don't care about and that there are more important things for Avid to fix/worry about and you'll see where I'm coming from.
As Spock would say: the needs of the many outweigh the needs of the few (or the one).
Old 09-05-2021, 10:51 AM
Yes I take onboard “for the many not the few” sentiment and in the grand scheme of things it’s not exactly life threatening so maybe I should just shut up about it. I will always find that “extra flap of skin” ugly though.
I have other niggling things that I can bore you with as well if you want. Just kidding. :)
Old 09-06-2022, 04:02 AM
simonchase simonchase is offline
Just put it up here. Then the flap is gone and we can see our timecode again.
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 09-06-2022, 04:18 AM
Yes - there's a lot of places the color selector can go. That and/or only open it when you need it then close it. It's easy enough to open and close it. I'd rather that Avid fix the cpu balancing than to spend time on this. THAT'S something that's important to all of us.
Old 09-06-2022, 05:23 AM
"I'd rather AVID spent time fixing stuff that's accidentally broken, rather than stuff they've deliberately broken"
Old 09-06-2022, 08:01 AM
I've had it top right of the edit window for years. It is (was) a great spot for it. I have spent a long time optimising my screen real estate.
Well that's what I do. But I use it all the time. It's very helpful to be always open.
I wouldn't. I never have CPU problems. But hey, maybe they could do BOTH. Wild idea I know.
Old 09-06-2022, 08:31 AM
daeron80 daeron80 is offline
+1. It's not OCD. It's a usability issue plain and simple. It's the difference between covering up or not covering up the marker tracks with something useless. The workaround is to make the Edit window shorter, which means it's showing fewer tracks at once.
David J. Finnamore
Bug in color palette OFS Pro Tools 2020 8 03-11-2021 01:39 PM
Color Palette gone... Possible bug? lapieuvre Pro Tools 9 0 07-15-2014 01:28 PM
Color Palette question RichrdC Pro Tools M-Powered (Win) 6 04-23-2009 09:21 PM
PT 8 Start Up Screen - Colour Palette Room335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-15-2009 07:08 AM
history palette for PT? munt factor General Discussion 1 03-03-2000 04:38 PM
