Old 01-28-2014, 04:44 AM
willeyh willeyh is offline
Default PT 11.1.2 - Drag from workspace
Just installed the latest build 11.1.2 and found a strange bug in workspace.
By dragging from workspace (copy on import or not) the file becomes a 1KHz sinus instead. (se pic.)
So I tried to import the same file via File-Import Audio and the file imported as it should.
So I thought it could be some issues with the file being a different sample rate, bit depth or even wav/bwav/aiff/quicktime code. But I couldnt replicate it to either or. It just happens suddenly, and a bit frustrating.
Any ideas?
I´m going back to 11.0.2.
Old 01-28-2014, 06:10 AM
joachim's Avatar
joachim joachim is offline
Default Re: PT 11.1.2 - Drag from workspace
Does not happen on Win 7 , PT 11.1.2HD with Mono or Stereo Files, wav or wav(bwf) , 24bit 48 khz.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 01-28-2014, 12:00 PM
mesaone mesaone is offline
Never seen that before. Does it play back as a sine wave? Maybe the waveform calculation got smeared.
Select the affected clip, open your clip list, then use the clip list menu to "Reacalculate Waveform Overviews".
Old 02-03-2014, 04:50 PM
Yes, it plays back a sine wave.
I went back to 11.0.2 and had no problems and I won´t be upgrading again until 11.2 or something so I can´t really check the "Recalculate Waveform Overviews".
This happened on my MacPro 3.1 ("unsupported" I know) running OSX 10.8 Mountain Lion.
Drag from workspace -- A way to Add NOT Convert i hear dead people Post - Surround - Video 2 10-11-2007 07:28 AM
BUG: Can´t drag from workspace when locked Frank Kruse Post - Surround - Video 4 02-05-2007 10:17 AM
Workspace Browser Drag swartzman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-05-2006 05:34 PM
drag from workspace is very slow breakie Pro Tools TDM Systems (Win) 0 11-20-2006 03:07 PM
Drag from Workspace Crashes wyman Pro Tools TDM Systems (Mac) 1 02-16-2005 12:12 PM
