Old 10-22-2012, 02:53 PM
#DarkBlu #DarkBlu is offline
Default Windows 8
Is ProTools MP9 and the Fastrack Ultra compatible with Windows 8, which is releasing in a few days? I haven't found anything on these forums or the AVID website indicating that Windows 8 is compatible. If it's not, I need to know, because I will not upgrade to Windows 8 if my Pro Tools MP9 isn't compatible and there won't be Fastrack Ultra drivers at launch.
Computer and CPU speed -PC AMD FX-4130 OC'd @ 4.2.75Ghz
OS version- Windows 8 32bit
M-Audio hardware model- Fastrack Ultra
Pro Tools version- Pro Tools MP 9 (Crashes Windows 8 every time)
Amount of RAM installed- 8GB
Recordings done on USB 2.0 external hard drive, 500GB.
99% disc space free.
If you listen to metal, you need to hear DARK BLU
http://darkblu.com/MEDIA.html
Old 10-22-2012, 09:05 PM
Default Re: Windows 8
Test at your own risk. I expect it to be at least 4-6 months before Avid gets through testing.
Old 10-22-2012, 10:17 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
Oh yeah - 4-6 sounds like a good time frame
If its working now just run with it - b/c in the case if win 8 u still have to take into account all of the indigenous bugs that will be present within the o/s itself
Then avid will have a poke at - compatibility
Daniel
Old 10-23-2012, 07:43 AM
dave911's Avatar
dave911 dave911 is offline
As far as I can make out without a touch tablet Windows 8 has nothing to offer and will probably run PT slower than 7.
Looks like they took W7 and slapped a new layer of stuff on top that wants to update constantly from the internet.
I wonder how hard it will be to turn off all that background updating.
Really hope I'm wrong on this, but it looks like Apple has driven Microsoft insane.
Old 10-23-2012, 08:30 AM
Benoni's Avatar
Benoni Benoni is offline
You can turn Metro off with a reg hack. I had PT9 running on Windows 8 Preview, and it ran alright, just took alot longer to start up.
HA! That's the funniest thing I've read in a while, almost made be spit my coffee out!
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 10-23-2012, 08:51 AM
dave911's Avatar
Did you see anything worth updating for?
I didn't do the preview so I'm going on the reviews and they are pretty negative for desktop machines.
Old 10-26-2012, 08:15 AM
Benoni's Avatar
Well, yes and no.
There is absolutely no reason to upgrade to W8 if you what to have support from Avid.
From my experience with the Preview, PT9 ran relatively well, save for a longer PT boot up time. PC boot up time was cut in about half however (which is about 20 seconds instead of 40) Of course this was all on the preview, I am expecting better performance from the official release, which is out today by the way (download it directly from M$ for just $39.99)
After I do the W8 Pro update I'll better know if there is anything really worth updating for, but there is probably not, unless you just like to use new stuff and don't mind not having any official support.
I would not do the upgrade unless you are proficient in doing your own troubleshooting, and have an image of your working boot ready to reinstall in case of a SNAFU.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 10-26-2012, 12:47 PM
dave911's Avatar
OK, Thanks.
The only general improvement I've seen is supposed to be some improvement in memory handling. Whatever that means.
Old 10-29-2012, 03:31 PM
Benoni's Avatar
I know I responded to this earlier, but I didn't address this specifically.
As i said you can easily turn off the Metro screen all together and have the same functionality as Windows 7, but you can also easily just turn off LIVE UPDATE to the tiles you are referring too. Simply Right Click and turn Off Live Update. You can also unpin them from the Start Page or uninstall them all together.
The new Start page is actually very intuitive and is a quicker way to find and launch the programs you use. You can pin any program or app to the Start Page, you can create Groups and name the groups, move groups or single apps or programs, its actually very nice. I'm up'ing all my PC's to 8
Just be warned that it is not supported by Avid, so only upgrade if you are fine with not receiving any help from Avid, and know there is a possibility that something may go wrong with PT or a plugin. Always have that working Image handy to avoid downtime and lost revenue.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 12-22-2012, 08:56 PM
Thanks for the replies.
I just used the Windows 8 Upgrade tool to see what was and wasn't going to work with Windows 8. Pro Tools 9 didn't show up in either the yes or no columns. I'm not jumping on Windows 8. It can wait. When AVID supports it on Pro Tools 9 officially, I'll update. Till then, Windows 7 will due.
Thanks again!!
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 01:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
running PT 8.0 in windows XP virtual machine on windows 7 Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-17-2010 08:45 PM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
